Thread: Which Intex Sand Filter for 22x52
    May 2012
    Las Vegas, NV
    92
    Looking for advice before I buy an intex sand filter. I don't know why the 28647EG (2800gph) is cheaper then the 28651EG (3000gph). This is for an intex 22x52 pool approx 10,000.
    Amazon.com: Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 110-120 Volt with GFCI, 2800 Gallon: Patio, Lawn Garden
    Amazon.com: Intex Sand Filter Pump with GFCI for Pools, 3000-Gallon: Patio, Lawn Garden
    Intex 22' x 52" Ultra Frame - approx 10,000 gallons of water
    Intex Sand Filter pump (8hrs Run Time)
    Krystal Clear Saltwater Model 7110/8110 (6hr run time/day)
    K-2006 TEST KIT
    38,521
    Re: Which Intex Sand Filter for 22x52
    You mean the 3000 is cheaper.
    For filters, bigger is better and the pumps are virtually the same.
    In fact the pump may be identical and the only reason they get a higher flow rate is due to the larger filter's lower head loss. {EDIT: this may not be true since they actually list the pump flow rate and the system flow rate separately.}
    Get the bigger, cheaper one.
    May 2012
    Las Vegas, NV
    92
    You're correct other way around. Thanks for your advice, ill order the bigger since its cheaper anyways and in stock.
    K-2006 TEST KIT
