Thread: Diamond Brite French Gray Pool Finish Inconsistencies
    Jun 2015
    Dallas/Texas
    1
    Hi all,
    We just had a new pool put in and it's going great. The only complaints are that the people that did the plaster didn't do a great job. On our tanning deck and pool steps, there seems to be a lot of big streaks where there is no aggregate visible. I believe this is because they didn't mix it long enough or mixed it for too long? I'm not quite sure. They decided to do the 'acid bath' method of exposing all of the aggregate which was fine (we didn't realize that it was the least desirable method until after they had done it, but it looks good nonetheless).
    I guess my question is, is there any way of getting more aggregate exposed where the streaks are? They are quite literally just streaks in the plaster that look void of any aggregate, they're just gray. Would a diamond disk polish it enough to make some aggregate underneath more visible? Or is there likely not any aggregate in those sections at all? In either case, is there a way to fix this and make it look a little better?
    Thanks guys! Sorry if this isn't the right area of the forum, I'm a newbie.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,535
    Re: Diamond Brite French Gray Pool Finish Inconsistencies
    HI! I hope someone will come along. If not try the under construction part of the forum.
    If you could share a pic or two that might be helpful also.
