Results 1 to 12 of 12
Thread: For all the TFP maintenance converts...
    Jun 2015
    Blue Bell, PA
    7
    What do you do when you go on vacation and can't add bleach daily?
    30k gallon, replastered (June '15), 1.5hp Hayward Super Pump, Hayward 60 sq ft DE filter, Hayward chlorinator, Rheem 406k heater.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: For all the TFP maintenance converts...
    Run my Rainbow 320 or have a neighbor fill my Liquidator.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    Trichlor pucks in a floater, same as most people
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,559
    I keep my CYA just a little under 40. That way I can put puck in to help hold the FC. I also pour in enough chlorine to bring my FC up to just over SLAM level.
    If I were to stay longer than just a couple of days I would have a neighbor come over to add chlorine.
    Kim
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    I usually throw 2-3 pucks in my skimmer basket and set the timer on my pool so my pump runs for 3 hours every 12 hours. If I'm gone for a week, I'll also leave three 1 gallon jugs of 8.25% clorox with my neighbor and I label them (If I leave on sunday, I'll label one for Tuesday, one for Thursday and one for Saturday). I just tell him to dump the jugs in the pool on the day they are labeled for.
    16'x32' Inground Vinyl, 21,100 gallons, Hayward 1.5 HP Super Pump, Hayward Pro Series S244T 3.1ft Sand Filter
    TFTestKits, Pool School, ABC's of Pool Water Chemistry, Chlorine/CYA Chart, PoolMath
    rdw1961's Avatar
    May 2012
    Mount Pleasant, PA
    17
    I have gone away for up to a week with no ill effects by bringing it to shock level, putting the solar cover on and shutting the pump down. When I get home I raise the Chlorine level again to be sure nothing is starting to grow and run the pump for 24 hours.
    24' Above Ground Round vinyl
    DE Filter pump 1HP
    Flow Rate 39GPM
    14700 gallon
    Jun 2015
    Blue Bell, PA
    7
    Thanks for all the responses.
    38,343
    Quote Originally Posted by Task View Post
    NOT recommended to do this. Pucks are very acidic and will make the water really nasty sitting in your skimmer if the pump is off. Then you suck it through all your equipment.
    Jan 2013
    Long Island, NY
    184
    Quote Originally Posted by rdw1961 View Post
    This! Except I keep the pump running for a few hours a day, just to circulate the hot water that builds under the solar cover.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    May 2015
    Paxinos PA
    57
    Originally Posted by Task I usually throw 2-3 pucks in my skimmer basket and set the timer on my pool so my pump runs for 3 hours every 12 hours.
    Good to know!!
    22,000 gal 16x34, IG, vinyl (7/14)
    DE Hayward Perflex extended cycle
    Hayward Super Pump
    Aquacal heat pump
    TF-100 test kit
    Task's Avatar
    Sep 2013
    West Grove, PA
    232
    I've gone as far as testing the water in my skimmer basket after soaking a couple pucks for several hours and haven't been able to detect a major difference in the test results. As long as you set your pump to run regularly, I don't think there will be any problems arising from supplementing your chlorine in this method while away on vacation, but hey, what do I know.
    swoopman's Avatar
    Jul 2014
    Annapolis, MD
    213
    Here's a great pic of pipe damage due to pucks in skimmer:
    Vinyl Pools, Pool Liners, Pool Service, Pool Renovations in Bucks County and Montgomery County
    Maybe not an issue if you just do it for a short time for vacation.
    TF-100 Test Kit
    22,000 gallon, 20x40 kidney-shape IG plaster pool built in 1986
    Nautilus NS-36 DE filter, Hayward Self Prime Super Pump 1HP
    Polaris Automatic Pool Cleaner, PB4-60 3/4 HP pump
