Results 1 to 7 of 7
Thread: CS8111 Intex Combo pump help!!!
    Jun 2015
    Belle River
    6
    I have the following filter which when I started for the first time this past weekend was really loud. From what I've read is more likely the bearing are shot and need replacing.
    Well I've reached the end of my limit in what I am able to do and looking for some insight on how to get the impeller and bearing out
    Here are some pics of what I mean
    This is the model of pump I have
    I'm stuck here
    Here you can see a c-clip, what is easiest way to remove??
    Any help would be truly appreciated
    Thanks
    Andre
    Jun 2015
    Belle River
    6
    Re: CS8111 Intex Combo pump help!!!
    Just so you know
    I've tried unscrewing the bolt that shows on the front of the impeller but it doesn't turn
    38,548
    Welcome to TFP!!!
    I thought those pumps were generally considered to not be serviceable. Looks like you have made some progress, but I have no idea what to suggest beside a C-clip pliers.
    Jun 2015
    Belle River
    6
    So I was able to pull the impeller away a little from the frame and found a c-clip hidden behind
    Jun 2015
    Belle River
    6
    Bearing number for this model is 608Z if anyone cares to document it somewhere
    Jun 2015
    Belle River
    6
    Here's the culprit to my loud noise
    Jun 2015
    Belle River
    6
    Update
    Well after a 5hr battle last night with this machine, i've replaced the bearings and it's back to purring like a cat.
    I will say that it did test my patience more than once putting this thing back together a few times but happy that i was able to get it working and save myself +$200 in buying a replacement.
