Results 1 to 7 of 7
Thread: Cloudy after vac to waste in deep end
    May 2015
    Lansdale
    7
    Why does my deep end always get cloudy while I vac to waste in my deep end? Before I vacuum to waste I was able to see the main drain in the deep end. During the vacuum process, it starts to get cloudy again. Whyyyyy????????
    ? gallon outdoor in-ground 'x' plaster pool
    Hayward DE6020 Pro-Grid 60-Square-Foot Vertical D.E. Pool Filter
    Century Centurion 1081 Pool Pump
    Polaris P945 Sport robotic pool cleaner
    38,283
    Re: Cloudy after vac to waste in deep end
    Because you are stirring things up in the pool when you are vacuuming.
    May 2015
    Lansdale
    7
    I hope it will clear up in the morning.
    38,283
    Are you sure you do not have a chemistry problem?
    Post up a full set of test results.
    30,419
    Why are you vacuuming to waste in the deep end? Is it to remove something visible?
    May 2015
    Lansdale
    7
    Yes Duraleigh.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Hard to tell what that is. Could be algae - aquatic dustbunnies - or Diatomaceous Earth. It would help us a lot - a whole lot - if you could fill out your signature with your equipment and post some test results. Instructions
