Results 1 to 7 of 7
Thread: Can You Tell Me What These Valves Do?
    nazran's Avatar
    Jul 2012
    Dallas Ft Worth
    55
    I purchased this home with pool. The yellow marked spa valves are used when I run the hot tub and the other marked valve controls the fountain height in the spa. The previous owner was unclear about the valves I have marked 3 and 4. Can someone help me identify?
    Thanks in advance...
    PS Also I am hesitant to run my string trimmer against those pipes. Should I just kill that grass with round up or some other thing to keep grass away?
    38,271
    Re: Can You Tell Me What These Valves Do?
    3 & 4 are pool suction line valves ... how many skimmers you got? I would guess 2 pipes are skimmers and 1 pipe is the pool floor.
    Right now you only have suction coming from the pipe labelled with the 3 arrow.
    nazran's Avatar
    Jul 2012
    Dallas Ft Worth
    55
    I have 2 skimmers. How should 3 and 4 be pointed so both are sucking
    38,271
    Look on the opposite side from the handle, It says OFF ... that is what is off.
    If you want all completely open, you would have the handles down with OFF facing up.
    Although I would suggest you play with the valves and figure out which pipe is which so you can balance the flow.
    nazran's Avatar
    Jul 2012
    Dallas Ft Worth
    55
    Thank u. I mow have suction on both skimmers
    38,271
    So you know pipe 3 is a skimmer. Put #3 handle pointing up to close that skimmer and then put valve #4 in the same position as in the picture and see if the pipe below valve 4 is the other skimmer.
    Mar 2015
    Harvey, LA
    300
    Also, your fountain height valve is part of the return...that is likely a proportional valve to determine whether to send more water to the fountain or to the return jets in the pool...so when you add chemicals by the returns you might want to turn the fountain off if the return pressure is low with the fountain on...
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
