Thread: Rusty brown water
    Jun 2015
    petersburg tn
    2
    Rusty brown water
    Hello. I bought a 22ft intex pool and had to use a water truck to deliver water to it. Well we filled it up and the water is a light brownish color. How can i remove the color form the pool and have it the pretty clear water that is suppose to be in it. Thank you in advance
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Rusty brown water
    Welcome!
    Iron removal goes like this: Add chlorine. Watch the pool get worse looking. Filter the Iron out with paper towels or pillow stuffing.
    Look at the pictures and see how simple it is. Doesn;t mean fast, but it is simple.
    Just got Taylor-2006 Test Kit. Want to verify what I should add.
    A Tale of Two Filters... and Ugly, Rusty Water.
    If the stuff gets really bad, you can even vacuum the rust particles up and then backwash them away.
    Could you fill out your signature? It helps us make recommendations if we know how big the pool is and what equipment you have. Instructions.
    Jun 2015
    petersburg tn
    2
    I bought some type of chemical called metal magic, the lady at the pool place said it would work
