Thread: CYA /
    May 2014
    hope mills, nc
    18
    CYA /
    above ground pool. Direct sunlight ALL day. NO shade at all. should I keep the CYA about 40? seems im losing a lot of chlorine every day? thanks
    Above ground 24ft round 54 in deep 1hp 2speed Hayward power flo matrix pump& sand filter.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: CYA /
    What is "a lot"? 4 ppm? 10 ppm? 15 ppm?
    Isolated Spa - 345 Gallons
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: CYA /
    40 is a good place to start. Then you can bump to 50 no probs and see if you gt any savings over chlorine loss.
    May 2014
    hope mills, nc
    18
    Re: CYA /
    well, trying to keep it about 5. and usually its gone or down to maybe 1 by the end of the day. is that normal?
    Feb 2014
    Central Minnesota
    5,080
    Re: CYA /
    That does seem like a lot even for direct sun at 40 CYA. What is your pool temp?
    I would bump your FC up targeting 6 or so tonight. Test after it's circulated for 30 minutes, then test early tomorrow morning. Overnight chlorine lost test (OCLT). You should not lose more than 1 ppm overnight. If you pass that, I'd go up to 50 CYA and see if that helps.
    38,237
    Re: CYA /
    You are letting the FC get too low ... you need to stay ABOVE the minimum at all times. See the FC/CYA Chart. Now that the FC has dropped too low, something could certainly be growing in the water making the FC drop more.
