Thread: splapool sand filter words have faded off...
    May 2014
    hope mills, nc
    18
    i have a splapool sand filter and the words have faded off of the top where you turn the handle to different positions. I know the most used positions, filter and backwash but would like to know the others. Have searched, without luck, online. Any ideas? Thanks
    Above ground 24ft round 54 in deep 1hp 2speed Hayward power flo matrix pump& sand filter.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,525
    Re: splapool sand filter words have faded off...
    Do you know your model number? If so you should be able to find the manual online.
    Goodluck!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    Experiment.
    You know waste will put water in the filter opening and out the waste pipe. Gauge should show zero pressure.
    Recirc will have suction in the skimmer and flow out the returns and no pressure in the filter.
    Rinse will look like waste but with pressure
    Closed will probably have the pump sounding funny.
    You know the other two. That's all, isn't it? Six?
