Thread: Need skimmer lid assistance
    I am not sure but I think someone replaced this lid or the part that it goes into. It does not attach to the part that is in the ground. So when you go to empty the basket the whole thing comes off. Any ideas how to fix it? don't think I want to glue it
    13000, AG, Plaster, Pentair equipment pump salt, automation, 3hp pump, 11 years old, TF-100 test kit, city water, pool cleaner vac, South Florida
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Need skimmer lid assistance
    That's how they are usually done. If you don't want it glued, I suppose you can screw it together. Why do you not want it glued?
    Essential Links:
    I wasn't sure if they are suppose to be not glued in case they break you can't get them off. It did end up fitting just now. I dug all around the opening. It is just below the dirt line. I am looking at extensions to raise it up a bit.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    They are a sliding 2 piece affair like so that when they're cast in a concrete deck the top portion can be positioned perfectly flush with the deck. In your case, where you don't have a concrete deck that you have to match up with, you're free to do whatever you like. Glueing it in whatever position you prefer is fine.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    oh so it doesn't have to be all the way pushed down? Even at its highest it is not high enough though. even for the dirt level. I ordered a extension piece to raise it up a bit.
