Thread: My pump question
    May 2009
    Trenton NJ
    497
    My pump question
    I picked up a pentair whisperflo 1 hp 220v two speed pump. I wired it for high n low. Toggle switch on the pump. Took L1 to the motor n L2 to the center position of the switch. My question is when in low speed the pressure gauge barely moves n boy it's slow. The returns barely moving water.
    Is this normal?
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    38,271
    Re: My pump question
    The pump should move about 1/2 the amount of water on low speed as it does on high. Normal for the pressure gauge to be pretty low. But, the your pump is a good bit larger than mine and I would expect you to have more flow than I do.
    Have you need checking the pressure on high to see if it has gone up by 20-25% over the clean pressure indicating you need to clean the filter?
    May 2009
    Trenton NJ
    497
    My pressure in high is 15 psi. No air leaks,. No bubbles in the basket either. But low the pressure is between 0-1. I don't know. I see water moving but boy. I plan on keeping it in low speed all day. 12hrs. on 12 hrs. Off
    I clean at about 18-20 psi
