Thread: Water replacement...am I approaching this correctly?
    Newpoolcrazy's Avatar
    May 2015
    La Porte, TX
    104
    Post Water replacement...am I approaching this correctly?
    Out of CYA reagent. It's on order, but it's late. I know a little rain doesn't make a difference with most things, but we were in that rain event where we drained about a foot of water out of our pool in 3 inch increments and it was replaced by rain water each time. Do you think this will lower my CYA much?
    What I'm doing is still shooting for the same FC as if my pool still had a CYA of 50 until I can test and see if it was lowered enough to need adjustment. Is this how I should proceed? I don't want my pool over chlorinated, but since no one is swimming because of weather anyway, I assume a little on the high side is better then low, yes?
    See? Just when we think I've got it, I get all newbie on you again.
    Cornelius Monterey Steel/Resin AG 18' round (approx. 7600+gallons) Hayward veri-flo SWG w/sand filter.Testing w/ TK2006 using Speed stir.
    38,251
    Re: Water replacement...am I approaching this correctly?
    Replacing 1 foot of water in increments lowered the CYA by 20-25%
    Safe to swim up to shock level FC, so I would certainly err on the high side.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,410
    Not a bad question at all. (no question is bad) With that much rain/drain your CYA will be lower.
    Kim
    May 2015
    La Porte, TX
    104
    So I could be down to a CYA of 40ish. I'm sticking with the plan. Thank you for helping me feel better in that decision.
