Thread: Skimmer question
    duckhunter27's Avatar
    Jul 2013
    Dannebrog, Nebraska
    59
    Skimmer question
    We have had our pool for 3 years now everything is great. But twice now in the last week I have came out to check on the pool in the morning and the basket in the skimmer is flipped up and cocked in the skimmer holding the door from opening all the way and making it hard for water to get in the first time I could hear something was wrong as soon as I went out not getting much water the second time this morning it was getting more water and not as noisy. Any idea's what is causing this? No one is messing with it not sure if a air bubble is in it when pump first turns on. I have the pump set to turn on at 5 am I usually check pool about 5:30 --5:45 am pump runs tell 10:00 am. I thought about putting something small and heavy in basket. But thought I would see if anyone else has had this problem or what is causing it. Thanks in advance.
    24ft x 52in Round AGP Heritage pool Aquamaster 19 in sand filter & 1 hp pump. Clear Solar blanket 12 Mil. TF-100 Test Kit. Pool filled June 3rd 2013 well water.
    38,235
    Re: Skimmer question
    Mine does that too ... I now keep a rock in it. Just make sure it is larger than the pipe hole in the bottom of the skimmer so it does not fall in if you drop it.
    Jul 2013
    Dannebrog, Nebraska
    59
    Thanks I also now have a rock in the basket has not happened again since.
