Thread: posts about scented bleach
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    I tried to search but I couldn't find many posts about WHY we shouldn't use scented bleach. What if I want my pool to smell lemony fresh?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: posts about scented bleach
    They usually advise against adding unnecessary additives to your pool water. It can be hard to determine ahead of time what the affects will be, and even harder to guess how to correct it. It may adversely affect some of the other chemicals needed.
    Donldson's Avatar
    NW Ohio
    2,917
    The scent lasts much longer than the chlorine, so it will build up if you keep using it and if you decide you don't want it anymore you will be out of luck. Your pool won't be the only thing smelling lemony fresh either, everyone who swims will as well and it may not just shower off.
    Also, you don't know what is in it. The general rule is if you don't know what is in it then don't add it. That all said, you probably won't actually hurt anything by adding it, but if anything goes wrong everyone is going to point to your use of scented bleach as a possible cause.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,637
    We have seen where the "special" bleach caused foaming.
    It is best to not add anything extra to your pool.
    Kim
    Mar 2007
    San Rafael, CA USA
    12,082
    It's the splash-less or outdoor bleaches that contain thickeners that cause foaming. The ones that are just scented-only are less of a problem, but as was noted above we generally avoid putting extra things into the water that you don't need. It's your pool and you can do what you want with it, but we have no prescription for removing the scented chemical if you decide to do so -- other than water replacement -- and we have no guarantees that it won't cause any other problems.
