Page 1 of 2 12 LastLast
Results 1 to 20 of 34
Thread: can't get dirt out the pool
    Mar 2015
    houma, LA
    28
    Not sure if this is the right place to post this. My numbers are great when I test. FC 4, CC 0, PH 7.4-7.6( been getting a lot of rain) TA 70, CYA 50. The water is clear and clean, the problem is dirt on the bottom of the pool. I will be posting a pic as soon as I can figure it out. I vacuumed 2 days ago and its been 3-4 days since anyone has been in it, yet the bottom is filthy. when I vacuum, I put a stocking over the skimmer basket to catch the small stuff. I did notice yesterday when the pump kicked on, it looked like it shot a cloud of dirt through the return. Anyone have some advice? I will get a pic up as soon as I can
    Intex Ultra frame 22'x52"
    Heritage wide mouth skimmer
    Intex 14" 3/4 HP filter/pump PVC piped
    This is our second year with the pool, hoping for some crystal clear trouble free fun this summer.
    Jun 2014
    15,093
    Re: can't get dirt out the pool
    Silly question maybe, but have you cleaned the filter lately?
    Mar 2015
    houma, LA
    28
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Is that a 14" Sand filter listed in your signature? Have you tried deep cleaning it? If Sand clumps up, it forms clods that have gaps between them and fine sediment can pass right through.
    Mar 2015
    houma, LA
    28
    Quote Originally Posted by Texas Splash View Post
    I backwashed about a week ago
    I super cleaned it and put fresh sand when I installed everything about a month ago. Could it be that dirty already?
    Richard320's Avatar
    Jan 2010
    18,988
    Quote Originally Posted by lucky1182 View Post
    Probably not.
    And now I can see the picture and it looks like algae clumping. Does the dust resemble aquatic dustbunnies? Does it go poof and disappear when you approach it with the brush or vacuum? If so, it's algae. Kill it.
    Mar 2015
    houma, LA
    28
    Probably not.
    that's exactly what it does when I get close to it. So would SLAMing be the way to go? FC has never been below2. CC has never been above 0. can alge still grow?
    Jun 2014
    15,093
    Yes, algae can still grow (and has), and it sounds like you do need to SLAM. Use the CHlorine/CYA Chart (link below) and match-up your current CYA to your SLAM FC level. Keep it there until:
    1. Water is clear
    2. You do not lose any more than 1ppm of FC overnight (that's the OCLT)
    3. CC (Combined Chlorine) is <.5
    ** You MUST meet ALL 3 items above to properly do a SLAM. Simply “spiking" the FC higher than normal isn't SLAMming, therefore there’s a good chance your algae will return.
    That chart is extremely important for SLAM and every day pool care. Good luck!
    Make sure to sweep/brush anything you see like that, and check any hidden spots that algae my hide (i.e. lights, ladders, etc)
    Richard320's Avatar
    Jan 2010
    18,988
    Yes. Because there are dead spots in the pool with poor circulation. It's not 2 FC everywhere, and right up next to some algae, there's probably none and if more chlorinated water doesn't get moved in to replace it, you have an algae bloom.
    You're lucky - you're almost there. A day or two at shock level and some serious brushing and it'll disappear and the water will sparkle. Just follow the instructions for the SLAM. Pay attention to Texas Splash's advice, too.
    Mar 2015
    houma, LA
    28
    Thanks everyone for the help. I got home from work and tested the pool
    FC 3
    CC 0
    CYA 50
    PH 7.4
    TA 70
    I added 387 oz of bleach, according to the pool calculator. Actually a little more just to empty the jug. I added the bleach about 5:30 this evening. I brushed it for about an hour. I'll continue testing, brushing, and bleaching until the OCLT is good. Thanks again for all the help. I will keep updating and let y'all know how it's going
    Mar 2015
    houma, LA
    28
    Update
    Just checked the pool, only 2 hours after brushing the pool cap was settling on the bottom again so I brushed it again. Fc is at 25. Will check it again in the morning
    Jun 2014
    15,093
    Keep up the good work. It will pay-off.
    Mar 2015
    houma, LA
    28
    6/19 update
    Tested at 7:30 this morning FC 20.5 dropped 4.5 over night. Raised FC back to 25 and brushed it again. Luckily I have a 3 day weekend so I can hopefully get this right before Sunday
    Jun 2014
    15,093
    Stay with it and "Maintain". Eventually your FC will begin to stay stead as it wins the on-going battle over the algae. Have a nice weekend.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,524
    I get that stuff too. In my case, it's just silt. I added some DE to my sand filter, and it helps a little. But no matter what I do, there's a certain amount of it every day to be vacuumed up. That's the result of living in a dry, windy climate -- lots of dust settles in the pool. Other than covering the pool when it's not in use, I don't know what you can do about it.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mar 2015
    houma, LA
    28
    Just tested again, I'm at 22 FC. I brushed the pool about 4 times today and added a total of 2 gals bleach. I also back washed the filter. Not sure if it makes a difference, but I added 1 gal of bleach direct to the skimmer. Will test again in the morning and keep this going
    Mar 2015
    houma, LA
    28
    6/20 a.m. Update
    Over the last 7 hours FC has stayed at 22, CC has stayed 0. When I get back from fishing I plan on vacuuming and back washing the filter
    Quote Originally Posted by jeffchap View Post
    Once I get through this SLAM I'm thinking about adding DE to the filter. Definitely not a dry climate here. Humidity is always crazy and we've been getting rain almost every other day.
    Jun 2014
    15,093
    Good job staying with that SLAM!
    Mar 2015
    houma, LA
    28
    Thanks for the support
    So I got home around 1 and noticed the stuff and the bottom was a lot less and also more green in color. Also when I brushed it the cloud was very light in color not brown like it has been. Anyone have some info on that?
  20. Back To Top    #20
    Richard320's Avatar
    Jan 2010
    18,988
    It's being bleached.
