Thread: Just getting started
    Jun 2015
    Sumerduck,VA
    1
    My wife has finally won! We are getting a 24x44 vinyl pool. Her major concession is that I get to build it.
    All help is welcome
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Just getting started
    Congrats! And welcome to TFP
    All the knowledge and help you need is right here. Don't be shy, ask away if you need too. Enjoy the forum.
    Essential Links:
    Jun 2014
    15,217
    Welcome to TFP Bruce. You have your marching orders, so good luck! Lots of DIY advice here a TFP, so if you have questions about the base, filtration, or anything else, just ask.
    Once the pool is complete and you know you're going to fill, get the "right" test kit (see TF-100 Link below). That's #1.
    Golden rule - Avoid the pool store for testing, advice, or products. You simply won’t get the advice/service you deserve and you will waste money on products your pool doesn’t need. Do not add anything to your pool other than what is advocated by the TFP site or its experts. You’ll have a happier pool, spend less time maintaining your pool, and probably save some $$ in the process. The following are short articles from this site that you will see linked in my signature below: Pool School, Recommended Levels (for YOUR pool), PoolMath Calculator, SLAM, and the Chlorine/CYA Chart.
    Welcome to TFP!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
