Results 1 to 7 of 7
Thread: Greetings from balmy Canada
    Jun 2015
    Southern Ontario
    9
    Wink Greetings from balmy Canada
    Hi everyone,
    I've been reading your site for the past 2 weeks and following your SLAM religiously for 1 1/2 of those, so I figured I should go ahead and sign up. I live in Southern Ontario (a few hours north of Toronto) and we generally have the pool open from late May-Mid October.
    We gained a 16X36' vinyl in-ground pool (~80000 L)when we bought our house in December 2013. My husband was thrilled and made it his project. Unfortunately, neither of us really knew anything about a pool and he spent all last season consulting 'experts.'
    The result was a pool that was swimmable for maybe 2 weeks total last season and ended up costing us ~$1500 in parts and chemicals. By the time we closed it, it was a lovely dark green. My husband was pretty discouraged and I wanted to fill the pool in and make a patio. This year, my husband and father opened the pool (still green), re-plumbed the filter lines to remove a non-functioning pool heater, and somehow ended up assigning the pool as "My project" to keep an eye on before work each day.
    I'll admit, I wasn't terribly enthusiastic, but I do like a challenge and turned to the internet to make a go of it and found this site.
    The SLAM was the first thing I'd heard or read that made sense, so I broke out the test kit and a Giant Costco pail of chlorine and got started.
    1 week after open
    2 days ago (after 3 solid days of rain)
    The photos speak for themselves, so I figured I'd join up and keep on reading here. You guys are already much better than the 2 different pools store we consulted with last year (one of whom sold my husband a calcium additive for our well-water filled pool. )
    Jun 2014
    15,298
    Re: Greetings from balmy Canada
    Welcome to TFP, and congratulations on your "assignment". Just a couple things for you:
    - I didn't see it above, so make sure you have the right test kit. You can get the Taylor K2006 mailed to you up there. The proper test kit is everything. Why? Because we've all learned (from personal experience) you cannot reply on pool store tests, test strips, or simple over-the-counter kits. They don't read Free Chlorine (FC) or Cyanuric Acid (CYA) levels accurately or to the high levels we need.
    - Next .. Avoid the pool store for testing, advice, or products. You simply won’t get the advice/service you deserve and you will waste money on products your pool doesn’t need. Do not add anything to your pool other than what is advocated by the TFP site or its experts. You’ll have a happier pool, spend less time maintaining your pool, and probably save some $$ in the process. The following are short articles from this site that you will see linked in my signature below: Pool School, Recommended Levels (for YOUR pool), PoolMath Calculator, SLAM, and the Chlorine/CYA Chart.
    Keep us posted on your progress or any issues you may have. Thanks for stopping by. Have a great day!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Welcome to TFP! Pool is looking good. Balmy, eh? Welcome to TFP! Pool is looking good. Balmy, eh? What is the Canadian definition of balmy? Here it is 95 or so. Isn't really hot until above 100.
    Let me convert to celsius like everyone but the US uses.
    In texas 35 is balmy and it isn't really hot until it hits about 38.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP! I'm impressed that you keep the pool open from late May-Mid October up there.
    Jun 2015
    Southern Ontario
    9
    Quote Originally Posted by pooldv View Post
    LOL! I suspect my definition of balmy is probably very different from a lot of people here.
    In celsius, Summer is anything above 22... balmy is above 24 and anything above 25 is bloody hot.
    We're light-weights in the heat department.
    We're often still swimming when it's down to 19 (depends on if you have a solar blanket or pool heater), but usually we close up the pools here around Canadian Thanksgiving...other than that you freeze your hands reaching into the water to close things up. The pool's currently up to 23 and we've been itching to get the clean up finished and get in, we've had some hot days lately.
    ~22,000 gallon (80000L) in-ground, vinyl pool
    mariane's Avatar
    May 2012
    Southeast Michigan
    305
    I'm from Detroit, and part of "southern Ontario" is SOUTH of Detroit. Isn't that crazy.
    With a heater, we're able to swim from late May till October.
    16 x 28 Doughboy Mystic Garden AGP with 7' deep end (used expandable vinyl liner) ~11,800 gals. Deep end main drain. Thru-the-wall skimmer, one return at deep end. Media Master 150# sand filter. Doughboy PowerPak II pump, 1 hp. Pentair MinimaxCH 150m natural gas heater. Polaris 65 when it feels like working . TF-100 test kit. No longer 'pool stored' 6 years and counting. In sunny but fickle metro-Detroit.
    Sep 2013
    Charleston, SC
    540
    I got home last night and my pool water temp was 97 F (36 C)! I drained about 5" and added water from our well to cool it down to 88 F (31 C). I emailed my best friend yesterday who also has a pool and she described her pool as, "jumping into a nice bowl of warm soup". Balmy is indeed relative.
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
