Thread: Raising Alkalinity
    Jun 2015
    Southern Ontario
    9
    Raising Alkalinity
    So I've just finished the SLAM mentioned here on our pool (took about a week and a half) and I can see the liner pattern in the deep end for the first time since buying the house last year.
    Next, though, my PH and alkalinity are too low (PH 6.8, ALK 60) and I just opened the pail to discover I don't have nearly enough Alka-booster to bring it back up...just wondering is there anything else I can use (we have lye at home) or do I have to bite the bullet and go to the pool shop tonight.
    Just wondering.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Raising Alkalinity
    Welcome, eh?
    I suspect alka boost is just repackaged overpriced baking soda. That being said, your alkalinity isn't that low. Your pH is what needs raising. Borax or washing soda will raise pH. Washing soda aka soda ash aka pH Up aka Sodium Carbonate (Not BIcarbonate) will boost pH and alkalinity at the same time.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    also, point one of your returns at the surface of the pool. the agitation/aeration will also raise the pH. I agree with Richard, your TA isn't way off.
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    Southern Ontario
    9
    Thanks!
    I do have one return pointed up, I just have to find somewhere that sells Borax or washing soda around here - they're surprisingly hard to find in our grocery stores.
    I'll see what I can find after work tonight.
    Update - looks like I can find Borax and A&H Washing Soda at the local CO-OP...I'm just picturing the look on my husband's face if I come home tonight and dump Borax into the pool. LOL!
    One more quick question: Would it be better to broadcast it through the pool or add it to the filter, or does it matter?
    Richard320's Avatar
    Jan 2010
    19,000
    Quote Originally Posted by Polar_Girl View Post
    Thanks!
    What chemical does what and how to add it is in Pool School - Recommended Pool Chemicals
    Jun 2015
    Southern Ontario
    9
    Thanks!
    I'll be printing that one out and hanging it on the pool shed wall next to my print out of how to do a SLAM.
    I'm going to have a lot of bedtime reading for the next few days.
    ~22,000 gallon (80000L) in-ground, vinyl pool
