Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: SLAM questionre
    Jun 2015
    Grapevine, TX
    12
    SLAM questionre
    I'm new to this and while preparing to SLAM my pool, I'm confused. My test kit only reads to 5 for chlorine. How do I know when I have reached the shock level of 28?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SLAM questionre
    Hello, and welcome!
    You need a specific kit for doing SLAM. If you truly need to do it, the TF100 is the best value for sure. What's going on with the pool needing a SLAM done on it?
    Essential Links:
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: SLAM questionre
    Patrick got it, order a TF100 and at least include the XL option. That will give you what you need while you are clearing the pool, and probably enough reagents for a couple of years normal use.
    The only other real option for a test kit is a Taylor K-2006. Be careful comparing prices because the K-2006 comes in sizes, designated by a letter. The basic K-2006 has .75oz bottles. Yo need to get the K-2006-C to get the larger bottles that you want. Even then it is a little short on the reagent & powder for the FAS/DPD test.
    I also have the SpeedStir and Sample Sizer. They speed testing and accuracy.
    Support the site
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: SLAM questionre
    welcome, perfect first question, get the TF100 test kit and we will get you going...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: SLAM questionre
    Welcome!
    What test kit do you have?
    Quite often, the pool stores sell the K-2005 DPD test kit and say it's the same as the K-2006 FAS-DPD test kit. You can buy just the missing test here: TFTestkits.net
    Jun 2015
    Grapevine, TX
    12
    Re: SLAM questionre
    Here's what's up: NO CHLORINE! None. Zip. No matter what. Yellow(?) algae. 2 yr old plaster, in ground pool, approx 15000 gallons. Leslie's water analysis report says CYA is 70, TA is 90, pH is 7.6. The test kit I do have agrees with those numbers including no chlorine! I am ready to rumble with my pool
    Jul 2013
    Fletcher, OK
    3,353
    Re: SLAM questionre
    well then "get ready to rumble"
    Leslies test can not be trusted, when you get a good test kit you will see the differance..
    Order a test kit today, you need a good one to SLAM and take control of your pool... TFTestkits.net Almost everyone will recomend the TF100 with the xl option, it will also make tests much easier with the speed stir but its not required...
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: SLAM questionre
    SLAM.
    after getting the test kit.
    pool store test results are not accurate and you cannot fix your pool based on them. Critical to starting is knowing your real CYA level.
    I had three pool stores test my water and give me results of CYA. results? 0, 0, and 100. actual CYA? 30
    they cant test for CYA and 95% of pool store employess have no idea the relationship between the level of stabilizer (CYA) and chlorine sanitizing power. we do. its in an easy to read table
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    Jun 2015
    Grapevine, TX
    12
    Re: SLAM questionre
    Ok, I'll order a new test kit. What can I do in the meantime? It seems the pool looks worse by the hour. Can I add bleach or ???? to keep it from getting worse?
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    Re: SLAM questionre
    how big is your pool? based on size, you can add 1 to 2 gallons of bleach per day. the test comes from north Carolina. if you order it today, bet you have it on monday
    Dan
    Jun 2015
    Grapevine, TX
    12
    Re: SLAM questionre
    15,000 gallons
    Jul 2013
    Fletcher, OK
    3,353
    Re: SLAM questionre
    1 gal a day will be fine until you get your test kit, that should be about 6fc.. untill we know exactly how much CYA you have its hard to say add more..
    Jun 2015
    Grapevine, TX
    12
    Re: SLAM questionre
    Ok. Test kit ordered and 1 gallon of bleach in pool. I brushed til my hands hurt today
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: SLAM questionre
    Have you scooped out all leaves and debris with a leaf rake? That will speed up the slam and use less chlorine.
    Jun 2015
    Grapevine, TX
    12
    Re: SLAM questionre
    Yes, the pool is free of debris. I am already excited because the pool does NOT look worse than it looked yesterday. In fact, after brushing and adding the one gallon of bleach, it actually looks better than it did yesterday. I will be ready to attack after my new test kit is delivered. Be ready, people, I will need your help! So glad I found y'all
    Richard320's Avatar
    Jan 2010
    18,967
    Re: SLAM questionre
    Remember to take pictures. You could end up in my Inspirational Threads thread.
    You can follow written instructions, that's a BIG plus.
    And just think.... with all that brushing, you're toning up.
    Jun 2015
    Grapevine, TX
    12
    Re: SLAM questionre
    OK pro's, I got my test kit and here are my numbers:
    FC - 5.50
    CC - 0
    TC - 5.50
    TA - 120
    CYA - 70
    Cl 3
    pH 7.50
    I have put 1 gal of bleach in the pool daily, since our last posts. I did NOT put one in today. The pool looks much better but there is still a bit of (I think) algae in some of the rougher spots of plaster, corners, etc. So what is my next order of business? SLAM? Please lead me........
    DFW, TX
    24,450
    Re: SLAM questionre
    Yep, algae likes hiding in the rough spots. And behind lights, in cleaners, under ladders.
    Lower PH a tad to 7.2. 70 CYA is a little high for a SLAM, but manageable. Just takes more chlorine to get to shock level.
    Here is the process, http://www.troublefreepool.com/conte...tain-shockingl. Don't skip any steps. You are off to a good start. The first few days it is better if you can test FC and add chlorine every 2-3 hours to see how well your pool will hold chlorine. Some pools with lots of organic material burn through chlorine rapidly at first, like 8-10 ppm per hour. Once you are holding chlorine level pretty well then 2-3 times per day of testing and bringing FC back to shock level will suffice.
    SLAM on!
    Please add your pool info to your signature as shown here, http://www.troublefreepool.com/content/165-getting-started
    Jun 2015
    Grapevine, TX
    12
    Re: SLAM questionre
    I added a signature. Let's see if it worked. I am a little computer challenged.
    15,000 gal, in-ground, plaster (new 2 yrs ago), attached spa, DE filter, AO Smith pump motor/2.20 THP
  20. Back To Top    #20
    DFW, TX
    24,450
    Re: SLAM questionre
    Looks good!
