Results 1 to 14 of 14
Thread: Drain/Refilled - CYA didn't go down - now what?
    Jun 2014
    SD
    26
    I drained and refilled 40% of my pool to reduce my extremely high CYA, alkalinity and chlorine. However, my CYA did not go down that I can tell! What is my next step?
    NEW NUMBERS
    FC = 9
    CC = .4
    PH 7.8
    Calc = 210
    TA = 325
    CYA = 150 - 'Guesstimate' because black dot disappears so quickly.
    I've learned so much about pool chemistry and the methods suggested here but I am frustrated the CYA didn't go down! Thank you for your suggestions!
    30,000 gallon, 20x40, IG, vinyl, sand filter
    30,403
    Re: Drain/Refilled - New Numbers - now what?
    About the only thing you can do is drain again. The pool is virtually unmanageable with a CYA of 150.
    Jun 2014
    SD
    26
    Does it make sense that it did not go down after the drain?
    Mar 2015
    Indiana
    79
    Re: Drain/Refilled - CYA didn't go down - now what?
    It probably did go down, but your cya was higher than the 150 to begin with. You need to do a dilution test to get a better guess at your actual cya. Dilute 1 part tap water with 1 part pool water and redo the test. Multiply the result by 2. If the dot disappears before you get to the 100 mark, then dilute 2:1 and multiply results by 3. You can keep diluting until you get a decent reading. I had to dilute mine 10:1 initially and learned my cya was about 500!
    17x41 Sun Fiberglass Pool 21,500 gallons. Jandy 1hp pump, Hayward Top Mount Sand Filter, Coverstar Auto Cover.
    DaninFLA's Avatar
    Apr 2015
    Sarasota, FL
    1,011
    your CYA was higher before is all. you said 150, did you do that by dilution? the higher the CYA, the larger the margin of error on the test. I believe I read that it is plus or minus 20ppm when you are at the upper limits of the test (100ppm). when you do a 50/50 dilution test, the margin of error goes even higher, probably 30.
    you need to keep emptying your pool and refilling until you get the CYA test results within range. larger water changes are better than multiple smaller ones if you have a deep water table. I would do 70% by default if you have a very deep water table and are able to do it. one 70% change is going to cost less time and money than multiple small refills. if you did two more 40% water changes, the net reduction in your CYA would be 64% and you would have used 24,000 gallons of water. a single 70% water change would lower your CYA by 70% and you used 21,000 gallons. so you can see how much more efficient that is
    I would do the larger drain/refill and then retest and see whats needed
    Dan
    9,000 gallon in-ground Saltwater pool, plaster, cartridge filer, 1.0 hp pump, Hayward T-15 SWCG, TF-100
    Pool School - Chlorine / CYA Chart; Pool School - Test Kits Compared;
    DesertPete's Avatar
    Jun 2015
    Palm Springs CA
    29
    Had the same experience. 3 Partial drains and still high CYA. Tried Bioactive twice and no better. So I finally drained the pool.
    15 K gal play pool (3.5' either end n 5.5' in middle) with attached 6 seat spa, all plaster. Built 2012. 3/4hp Pentair Whisper-Flo pump (model 177449) and a 2hp Pentair Super-Flo for spa (model 196240), Pentair Clear-Plus 350 sq ft filter (model CCP320) Master-Temp 400 gas heater. Use 16 mil blanket to control heat n evap. Live in desert, summer 114 winter 70's.
    Jun 2011
    Long Beach, CA
    2,778
    When you replaced 40% of the water, 40% of the CYA was removed. You can't measure that difference because the CYA is extremely high and the test only reads to 100. The CYA test is logarithmic, so any reading above 100 can be way over 100 such as it is in your case.
    The best option for you is for you to continue draining and refilling until the CYA hits 50 or less. Don't drain all at once with the vinyl liner.
    Donldson's Avatar
    NW Ohio
    2,881
    Quote Originally Posted by sdaggie View Post
    By your description I would say it is far more likely your CYA is easily a couple hundred and was several hundred before your water change. I would do another 40% if you can, there is little risk of overshooting it at this point.
    BTW, I hope that some new people see what the pool store has gotten you in to between this and your TA. Not that it was your fault, you had no reason to believe they were steering you wrong, but what a mess.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    DesertPete's Avatar
    Jun 2015
    Palm Springs CA
    29
    Thank you for the pool store comment.
    Jun 2014
    SD
    26
    I just completed my second partial drain and refill due to sky high CYA and TA. Here are my new numbers:
    FC = .4
    CC = .4
    PH = 8
    TA = 320
    CH = 225
    CYA = 72
    The water has a greenish tint to it after refill. What should I address first - PH or chlorine?
    Thank you for your advice - I am new to this method but I have to admit, throwing in a bunch of shock is looking very easy right now - but I am trying to stay strong
    Last edited by tim5055; 06-24-2015 at 03:47 PM. Reason: Realign post into it's proper position
    poolnoob.ca's Avatar
    May 2014
    Georgetown, ON, Canada
    277
    Sdaggie, throwing in a bunch of shock is a pool store technique, and what likely got you in this mess in the first place. You just may be adding lots of chlorine in the near future, but i suggest doing it in a controlled scientific method, the SLAM.
    As for addressing pH and chlorine, you can address them both today, 1/2 hour apart. Use pool math to get pH to 7.2 in preparation to SLAM, and get chlorine up to 8ppm with bleach or liquid chlorine as your CYA is about 70
    32,000L Fibreglass Leisure Pools IG 12.5'x23'x5' Pump: AstralPools BX1 1.0HP
    Filter: AstralPools ZX-310 SWCG: AstralPools VX7T
    Heater: Hayward H250FDN Test Kit: TF-100
    Mar 2015
    Upland, CA
    222
    Re: 2nd Drain/Refill - New Numbers
    Chlorine. In comparison pH is a minor concern. Make sure you add enough chlorine for your current CYA.
    How are you getting such exact numbers for your CYA?
    20k gal. IG plaster w/spa. 2 HP Aqua-Flo "A" pump, Hayward DE6020 filter. "The Pool Cleaner".
    Jun 2014
    SD
    26
    @sbcpool - I had to do the alternate CYA test with partial tap water and multiplied by 2 to get 72.
    Donldson's Avatar
    NW Ohio
    2,881
    If your CYA is below 100 then you don't need to dilute the test, in fact doing so causes a higher margin of error. Redoing the test without dilution will give you a more accurate reading.
    Assuming your CYA is around 70 or 80 then you can start a SLAM if you want, but it will take a decent amount of chlorine to get your FC high enough. It would be better to bring it down a bit more, but that's your call. If you are really chomping at the bit and are willing to use some extra chlorine then you can begin. Be sure to bring your pH down before starting.
