Thread: wooohoooo!!
    MirellaJoe's Avatar
    Jun 2013
    Aurora, Ontario-Canada
    125
    Red face wooohoooo!!
    Hubby has finally agreed to get rid of my solar heater for a propane heater!!! we are looking at the pentair MasterTemp® 125 125btu or the RayPak 156A 150,000 BTU. I just got a guy to come and quote me on propane tank rental, price etc etc. I'm so excited!!!
    My question is if u had the choice which one would u get?
    Intex Ultra Frame 16'x48" sand filter w/intex SWG.
    Pool Blaster Max Vacuum
    3rd year with Intex and no problems
    Pentair Mastertemp BTU 125/ propane
    Taylor K2006 Complete FAS-DPD
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Re: wooohoooo!!
    Bigger is better. It's BTU/hr. So twice as big a heater will heat the pool in half the time.
    Jun 2012
    western NY
    1,560
    Re: wooohoooo!!
    That will be plenty of heater for that pool. Probably get almost 3 deg/hr of temp rise.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    MirellaJoe's Avatar
    Jun 2013
    125
    Re: wooohoooo!!
    thanks guys! i'm so excited!!
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: wooohoooo!!
    You might consider keeping the solar arc even with the heater. You can use the heater to warm up the water and the arc should help replace some of the heat lost to evaporation to maintain the warmer temp. Just pipe the arc U/S of the heater and you're set. Only downside is that you heater temp will read the temperature of the water leaving the arc and not that of the pool.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    ps0303's Avatar
    Jul 2011
    FL
    3,695
    Re: wooohoooo!!
    Go for the Raypak but get a 200,000 BTU unit. You'll be a lot happier and it's not that much more in cost.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
