Thread: Using test kir
    Using test kir
    I got my TF100 test kit with magnetic stirrer.
    Where do you start? What do you test more then other tests?
    Do you do them all daily?
    I would think a couple every 2 days and the rest once a week.
    I'm in Phoenix so it stays hot
    I'll be back home from work this evening and going to break into this test kit
    Jun 2014
    15,229
    Re: Using test kir
    Welcome back and congrats on the kit! The kits comes with an instructions card(s). Doesn't matter really which one you test first, just test them all and post back here your results of: FC, CC, TA, PH, CYA, and CH. If/when you need to adjust chemicals, then we may suggest a specific order.
    Also, please add your pool info to your signature by going to the top of the TFP web page (just under the Pool School button) and select "SETTINGS". On the next page look to the left for a menu bar that says, “MY SETTINGS” and go to "EDIT SIGNATURE" to enter your pool and equipment info there. It will help us later.
    We look forward to seeing your test results. !
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: Using test kir
    You'll want to run all the tests now.
    If anything seems wacky, hold off and check Extended Test Kit Directions especially the TA static electricity note and CYA diultion. In Phoenix, I'd expect to see high CH, so don't give up too soon. And let the speedstir do the work on that test for sure.
    Once you get comfortable with testing and know your results, use Pool School - Basic Pool Care Schedule
    Jun 2014
    15,229
    Re: Using test kir
    Once your water is balanced, testing the FC (free chlorine) every day is critical. Many other tests can be done weekly (a couple others longer than that).
