Results 1 to 8 of 8
Thread: Pentair ColorCascade LED Bubbler - water depth?
    Jul 2014
    New England - MA
    310
    Anyone have the Pentair ColorCascade LED bubblers in 12"+ of water? The specs call for depths of 2-10". Was planning on doing my sun shelf at 12" deep with a bubbler or 2. Not sure it will be worth it if I'm too deep.
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    May 2015
    Houston TX
    49
    Re: Pentair ColorCascade LED Bubbler - water depth?
    We will have a tanning ledge and were going with 12" depth. Will will also have Pentair LED color cascade bubbler. You are right about the depth. Our pb changed the depth to 9".
    Houston,TX, IG 15120 gal, gunite, 22' x 36',wet edge finish, Pentair equip, 420 cartridge filter, vs pump, Intelliflo vs booster pump for water features, 400,000 heater, auto fill ,PCC 2000 in floor cleaning ,2 LED lights,travertine coping, paver decking, 9x12 tanning shelf ,1 LED color bubbler, 2 5' benches w jets. Depth 4- 4 1/2- 5 , wall with 3 24" sheer decent , 2 spray heads, Intellitouch Controller.
    Jun 2013
    Phoenix, AZ
    25
    Oh something I am useful for. Just like you guys, I had planned to do a gigantic tanning ledge 9" deep or 6" of water, but the layout guy convinced me to go make it a second step. When I get home I will measure what my actual water depth is for them. Pentair sends it with a 6" vinyl extension designed to keep the water effect straight but also helps in deeper than spec water.
    While not the 2 foot tall fountain Pentair shows in their brochure, it is still a nice effect. Especially considering the pump is also powering a gigantic grotto waterfall, 2 laminars and 2 colorcascades at 3000 RPM.
    Instagram
    Complete 6/4/15 - 22,000 Gal - IG - 40'x29' - Electric Blue with Blue Bead and Pool's Gold Baja Mini Pebble
    2 Pentair IntelliFlow Pumps - Clean and Clear Plus Cartridge 420 - IC 40 SWG - MasterTemp 400,000 BTU Heater - 8 Foot Grotto - 2 Laminar LEDs - 2 Color Cascade Bubblers - 2 Intellibrite 5G LEDs
    May 2015
    Houston TX
    49
    Quote Originally Posted by ragedogg69 View Post
    Instagram
    Thanks for your help. I'm not sure I understand. But I'm very interested in your help.
    Mar 2015
    West Palm Beach, FL
    56
    I am having them installed in my pool but haven't filled it yet. Water depth on my shelf is about 6-8 " though.
    Dig started 5/6/2015!! 17x37 pool. 6x8 Ledgestone spa with 6 jets. Sunshelf w/ 2 illuminated bubblers. Pentair Intelliflo VS pump. Silencer 1hp spa blower. Pentair Ultratemp heat pump. 3 Globrite LED lights in pool, 1 in spa. Travertine marble deck. Easytouch 8 automation. IC-40 SWG.
    Jun 2013
    Phoenix, AZ
    25
    My water depth is 19" and the bubblers come out of the water 6 or 7 inches. Obviously, shallower the water, the higher the plume.
    Apr 2015
    Haymarket/Virginia
    8
    It should work just fine, my PB said I could probably shoot mine 10 foot in the air. Haha
    New Pool build summer 2015 - IG / 24ft x 43.6ft freeform / 50 sq.ft spa, raised and overflowing / SWG / Hayward equipment: 2.5 hp 2 speed and 1.5 hp tristar pumps /450 sq.ft Cartridge, 400k heater, PS8 Controller, Wifi Aqua Connect and Aqua Pod, 2 large LED Lights and 1 spall / SharkVac XL / 35 foot RBB with 2 sheer descents / 56sf tanning ledge w/ LED bubbler / Quartz paster / aggregate decking.
    Aug 2017
    Cave Creek, AZ
    3
    Do you have any pictures of them in operation at that depth?
