Thread: Pump Suction Issues
    Jan 2015
    Puyallup, WA
    50
    Pump Suction Issues
    So I have the basic Intex Pump with Sand Filter(SF15110) with the basic over the wall skimmer. There are no problems with the pump and sand filter works awesome has lot's of suction and the return flow is good as well until I put on my Intex vacumn kit. What am I doing wrong? I submerged the vacumn and all the hose then attached it to the skimmer housing and at that point it has suction for about 2 seconds then we lose it.
    Also when we lose the suction and put the skimmer back to normal it takes awhile to regain the suction. Is there a procedure on how to get the suction back once you lose it.
    Help please all i want to do is vacumn my pool
    20x10 Intex Pool
    Sand Filter SF15110, Solar Cover
    TF-100
    Re: Pump Suction Issues
    I have this problem sometimes. I make sure the vacuum is attached securely to the wall skimmer. If that's fine I often toggle the lever on the sand filter in case the filter stopped running as strongly. If that doesn't work I backwash and that usually does it for sure. If I think of more things I've tried I'll let you know. We also installed a larger skimmer but honestly the vacuum attachment for that set up has to have strong suction or it won't stay connected. So that most of the time is the issue.
    Rebecca and Pat Loebach
    Peoria Illinois 61604
    tridoc927@yahoo.com
    http://www.renovatemyranch.blogspot.com
    http://www.embersgarden.blogspot.com
    http://www.drrebeccaknight.com
    Intex Ultra Frame 12x24 52" AG pool. 8,403 gallons
    Intex Krystal Clean Sand Filter Pump with 1,600 gallon per hour flow rate. Intex Krystal Clear Saltwater system.
    Dug 18 x 30 hole, 4' deep, put pool in hole and built retaining wall around it. Currently working on deck surround/topper.
    Jun 2015
    Ohio
    3
    Everytime i hook up the vaccum i take the vaccum hose hookup and put it up to the pump out take and fill it up with water till it floats to the top and starts sinking.. also if you cant get good suction purge the pump by twisting it open and closing it till it regains.
