Ran a used dolphin pro for the first time today while trying to clean up some dead algae and leaves after a SLAM.
Some things I've noticed:
1. While the pool cleaner is cleaning, occasionally some small debris will simultaneously come out from the top impeller.
2. When removing the pool cleaner at the end, a ton of dirty water and debris falls back into the pool while I'm lifting it out. (I've read to slowly tilting the cleaner out of the water, tried it during a second clean and didn't work)
Does this happen to anyone and any remedies? Also, when cleaning the robot, is it safe to just hose down the entire inside?
Thanks! This is the pool cleaner I have.
