Thread: Teflon Tape on Pool Sweep Fitting Threads?
    May 2015
    Moorpark, CA
    171
    I'm new to pools, so I don't know what the recommended procedures are with regards to PVC pipe fittings. I am about to reconnect my repaired pool sweep to the pressure port on the side of the pool, and was wondering if I should be using Teflon tape on the threads.
    Michael
    20,000 gallon in-ground gunite/plaster pool (1992), attached spa with spillway, Pentair Superflo 1.5 HP pump, Smith booster pump for pool sweep, Pentair 2000 DE filter, Sta Rite Max-E-Therm 400 heater, Silencer Blower 2 HP for spa, Polaris 280 pool sweep.
    Jan 2012
    'burbs of Augusta, Georgia
    7,364
    Re: Teflon Tape on Pool Sweep Fitting Threads?
    No, I wouldn't. Don't you ever remove the pool sweep from the return? I take mine out all the time such as during parties or when I want to hook a fountain up.
    May 2015
    Moorpark, CA
    171
    It's actually has a quick disconnect that is screwed into the port on the side of the pool, and then the pool sweep connects to the quick disconnect.
    Michael
    Feb 2015
    Davis, CA
    97
    I don't think it makes any difference. The teflon tape is used to make a water proof seal. So what if your joint leaks. It's in water - so it won't matter. And if the leak is so huge that it matters - then I doubt any amount of teflon tape would make a difference.
    Pool Remodeled June 2015. 18K Gallon IG kidney shaped. Pebble Tec (Tahoe Blue) finish. Jandy ePump 2HP. Hayward SwimClear C2025 filter. Hayward SWG. Jandy iAqualink RS6 automation. 6 Deck Jets. Pool Remodel Link Future: Acid automation. Chlorine automation for winter. Solar panels.
    May 2015
    Moorpark, CA
    171
    Thanks!
    Michael
