Thread: broken bulkhead fitting
    Jun 2015
    New York
    4
    Question broken bulkhead fitting
    Hi all,
    I have a Heldor Clearflo DE-24 filter(I don't think the company exists anymore) that's almost 30 years old. It was there when we bought the house 2 years back. I think because of the repeated push and pull of the backwash valve, the bulkhead fitting that connects the DE filter unit broke because of the weight imposed, shown in the picture below. I tried to search for the part (part # 194892) online but couldn't find it and came close to this one, http://www.poolpartsonline.com/p-523...4601-4801.aspx. The bulkhead connects the DE filter pipe in the 2nd pic. The other end connects to the top pipe in the 3rd pic. The price for this piece seems pretty ridiculous, also given that it may not even fit. Is there another alternative I could approach instead of buying this part? Any advice is appreciated.
    Thank you
    30,431
    Re: broken bulkhead fitting
    I think you got your money's worth out of that one and would spend the money for a new multi-port valve.
    For that matter, I would get a new filter AND multiport at the same time......you'll never look back.
    Jun 2015
    New York
    4
    Thanks for the reply. Is this possible with the existing pipes in the filtration system, where only the filter w/ multiport valve have to replaced with as little plumbing needed?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yep, pretty much. I'd go that route, and at least consider a sand filter for simplicity. A very personal choice, but one worth considering.
    Essential Links:
