Thread: Anchors for safety rope
    Jun 2015
    Fenton, MO
    7
    Hello - I'm,new to this site. I have cantilever coping and don't know which anchors to get or where to put them. I don't want to make a hole in my liner and don't want to drill into the concrete edge either...Any suggestions?
    Last edited by BoDarville; 06-17-2015 at 10:09 PM. Reason: Edited for readability and to remove references to old thread
    Jun 2014
    15,259
    Re: Anchors for safety rope
    Hello and welcome! I see you haven't received a reply yet on your post. I just wanted to let you know we haven't forgotten about you. This reply should get your posting back to the top of the queue where hopefully some with experience with your question can provide some answer. Thanks for checking-in with TFP, and have a great day.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Hi there,
    welcome to TFP,
    well, there really isnt much of an alternative to installing anchors either in the pool wall or the deck. I really wouldnt recommend putting anything through the liner.
    May not be much of a choice but to put a concrete anchor into the deck. Something like linked below, and then put a Eye Bolt in it to connect the rope to. The eye bolt cold be removed if you wanted to, leaving just the anchor in the deck. Thats about the only suggestion I can give you
    Swimming Pool Brass Anchor for Loop Loc in Ground Winter Safety Covers | eBay
    Quote Originally Posted by angiepalazzolo View Post
    Divin Dave,
    Jun 2015
    Fenton, MO
    7
    Thank you. I'll talk to my concrete guy and see if you can work this in some way. I have these anchors - will they work?3839-0.jpg
    15,000 gal 14x28 IG vinyl liner pool - Hyrda Pools, Hayward sand filter, Hayward 1.5 Pro pump, Aquarite 1500 salt water generator. Install June 2015.
    Jul 2014
    Hope Mills, NC
    569
    Those are what my rope attach to, well, used to attach to. The rope dissolved! They are screwed into the coping.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,824
    Definitively recommend the Loop-Loc style anchor from DD's post. You won't need anything else except maybe the brass masonry anchor collar that goes with it. The collar normally sits flush to the deck but you can use it by lifting it up when the anchor is extended up, to create a lip for the rope so it won't slip off. You may not need it but it would surely keep the rope on.
    You'll just have a loop in the rope that goes around the anchor. When not in use, the anchor just gets screwed down and is either flush with the deck (no collar) or sits up just slightly if the collar is in use.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
