Thread: hours for running the pool pump
    May 2015
    Des Moines, IA
    65
    How many hours a day do I need to run the pump in our pool? it is a 18X34 above ground pool, about 25k gallons....
    thanks
    we have an above ground 18 X 34 sand filter
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,030
    Re: hours for running the pool pump
    Answer: probably much less than the pool store expert says.
    There are too many variables at play. How many swimmers? How much blown dust? How big a filter? You'll just have to experiment and find out. Here's how Pool School - Determine Pump Run Time
    May 2015
    Des Moines, IA
    65
    thank you!!
