Results 1 to 9 of 9
Thread: Suz's tap water for practice
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    I finally tested our tap water to practice using the kits.
    Here are my results with notes on what I THINK I should do if this were pool water (SWGS):
    FC = 1.5 should be 4-6 ppm; add bleach
    PH = 7.2-7.5 ok
    TA = 230-250 should be 60-80 ppm; not sure what to do
    CH = 275 ppm ok
    CC = 2.0 should be <0.5; SLAM (whatever that means)
    TC = 3.5 can't find anything about this
    I never did well in Chemistry class. I lived in a small town, and our Chemistry teacher was a Baptist minister. Nice guy, but I learned more about the Bible than chemistry.
    Thanks! Suz.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Re: Suz's tap water for practice
    From the tap, that CC is not worrisome. They use it as a sanitizer. It should go away with sunlight.
    The high TA will push pH up. Don't be surprised if when you get the pool filled and circulating, that pH is higher than you tested today. Adding acid to lower pH will also lower TA.
    Apr 2015
    Houston, Texas
    3,217
    Thanks, Richard!!! I'll need more help when it gets closer to fill time. I'm probably a few weeks out from plaster - too much rain!!! Take care. Suz.
    Feb 2015
    Richmond/TX
    58
    Somebody with more experience please correct me if I'm wrong. I recently filled our new pool and prior to fill tested my water and came up with a plan. Nothing I came up with actually happened. From memory I had the following
    FC - 1
    CC 1
    TA 70
    CH 125
    What ended up happening was that the TA went to 0 due to the acid start that the PB did (thank you Patrick for steering me straight on that one), my CH eventually ended up at about 425 I assume due to the plaster curing, I ended up doing a partial drain and refill to get it down to 300. So my advice which is given in hindsight is keep an eye on pH and chlorine levels for the first week or so then if PB has left it to you start getting your other numbers in line. It is amazing how quickly you seem to get to know what your pool water is doing, especially with pH and Chlorine, I'm about three weeks in and have my TA looking pretty good, my pH still rises but I can pretty much guess what it will be before I test and the Chlorine is finally holding better with a CYA between 20-30 (still going up with chlorine tabs) I would not rush to adjust water chemistry at the start, let everything settle down, pH and FC monitoring and adjusting will be key and take your focus to start with.
    16,800 Gal IG, Luna Quartz Aruba, Pentair 420 Cartridge Filter, Pentair 4x160 Inteliflow VS Pump, Pentair Intellachlor SWG, Paramount PV3 w/ 1.5 HP Pentair WF, 2 HP Pentair WF supply Water Features, Easytouch Control System
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Suz, don't worry about TC. It's only the sum of FC+CC. As long as you break those numbers out in your results, we can see it, but we don't really use the number for anything.
    Your numbers are pretty good, but as Richard said, you'll have to watch pH close, because it will want to climb on you. No worries, we'll help you on that if you need it. I can't say if smurf blue will have a bearing on your numbers, so we will have to see.
    I'm sorry about your chemistry lessons, but OMG...that was so funny!
    Essential Links:
    Jun 2014
    15,221
    Suz, I think you should call your water company and tell them they need to "SLAM".
    Apr 2015
    Houston, Texas
    3,217
    Patrick: Thanks for your reply. I'm not losing any sleep over this. Since I taught school for 25 years, I know things make more sense when you're actually doing them. I just don't want to wake up to a green pool - especially not with Smurf Blue! Adjustments are expected, but I'd rather things not get out of hand.
    Splash: Hilarious!!!! I'd love to call the water company and tell them a thing or two. Most of our utilities around here are run by very nice companies. And our water used to be run by a local utility district. We could always talk directly to Joe Local Guy. But then we were switched from well water to lake water, and a new big company took over. They are just vial people. I wish I had the numbers on our old water. I think it would be interesting to see what differences there are.
    Question: I found a really nice chart (I love charts and spreadsheets) from "Flotsam" on TFP dated 5-3-11. Someone probably recently suggested it, or I found it by googling. It seems good, but I had to save it as a picture and then print, so the resolution isn't great. Can someone tell me how to download it or get hold of document file? Or..... do you guys know of a more recent and/or better one to keep track of my test numbers?
    Thanks for now and for all future help!!!! Suz.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Hi Suz,
    dont worry too much about being a chemist. All the work has been done you just need to find the info.
    Pool Math is your friend. Have you seen it yet?
    http://www.troublefreepool.com/calc.html
    And here is a pretty cool spreadsheet that you can download.
    Jesse's Graphical Pool Testing Log (Excel spreadsheet)
    And about all I remember from high school chemistry is H20, o2, and a girl named julie!
    Divin Dave,
    Apr 2015
    Houston, Texas
    3,217
    Divin Dave: That's great - about what you remember from HS chemistry!!! I remember Donnie!
    Yes, I've seen pool math..... I'll try it when I test our friend's pool water.
    Thanks for the link to the testing log spreadsheet. I'm going to it right now! I so appreciate everyone's help here!! You guys are awesome! Suz.
