Results 1 to 8 of 8
Thread: How are my numbers
    Queenbee's Avatar
    May 2014
    Vancouver, BC
    13
    How are my numbers
    I received my TF100 kit today, so excited to become a pool genius!
    Here are my numbers
    FC 9
    CC .5-1 I initially used 1 drop and seemed to be clear but after a few seconds turned a little pink so used a second drop that is why I said between .5 and 1
    TA 170
    CYA 55
    CH 300
    Let me know if I need anything else.
    Thanks
    21K Gallon, IG Vinyl, Hayward 1HP Superpump, Hayward 425 sq ft Cartridge Filter C4030 (flow rate 150GPM), Hayward Aqua Rite SWG, Hayward 250K Gas Heater
    Completed Oct 2013 in Vancouver, BC
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    Re: How are my numbers
    pH is critical. You don't need to use the yellow OTO TC test on the other side, but do test pH.
    You can raise CYA and probably reduce pump and/or SWG on-time as well. Pool School - Water Balance for SWGs
    Queenbee's Avatar
    May 2014
    Vancouver, BC
    13
    Thanks Richard, I forgot to post my PH is around 7.8
    I'm sure I will get better with time but it looks closer to the 7.8 than the 7.5 to me
    Richard320's Avatar
    Jan 2010
    19,052
    Quote Originally Posted by Queenbee View Post
    In that case, target 7.2 pH in poolmath and add some acid. That will help lower the TA, too. If you don't have acid on hand, don't panic. It can wait until tomorrow. 7.8 is still acceptable pH.
    Queenbee's Avatar
    May 2014
    Vancouver, BC
    13
    Thanks Again Richard,
    In pool School it says that for a SWG that the PH should be 7.5-7.6 and not any lower. Is this still correct?
    Richard320's Avatar
    Jan 2010
    19,052
    Yes, it is correct after you lower the TA. You'll start to notice the pH will take longer and longer to rise and take less and less acid to lower. When it settles down and TA is in range, then you can let pH sit higher.
    Queenbee's Avatar
    May 2014
    Vancouver, BC
    13
    So as my PH rises should I continue to bring it back down to 7.2 until my TA is in line?
    Richard320's Avatar
    Jan 2010
    19,052
    Yes. And then you can follow the pool school recommendations for levels. You'll know when you're close because the pH rise will slow down quite a bit.
