Ph not raising with Borax
I did add pucks in an effort to raise my CYA. It was down around the 30 level, and with summer upon us I full swing in Florida, I figured I needed the CYA a little higher to keep the chlorine working at an optimum level. So is that what's keeping my Ph Low? Also, is 7.4 acceptable?
7.4 is certainly between 7.2 and 7.8, so it's fine.
Every pound of trichlor - 2 pucks - will raise FC by 5, raise CYA by 3, and lower pH by .27 in a pool your size. It will also lower the TA some.
