Thread: Ph not raising with Borax
    Jul 2014
    Navarre, FL
    5
    Having a wierd deal with my Ph. It keeps reading 7.4 and the calculator says 39 ounces of Borax. Two days later, I'm back to 7.4? My TA is 70. FC is 10. CYA is 45. What am I missing?
    22K IG Vinyl, Sand, Hayward Ecostar w spillover spa & Haward Navigator
    Screened enclosure w Southwest exposure
    Donldson's Avatar
    NW Ohio
    2,904
    Re: Ph not raising with Borax
    May I ask why you are trying to raise your pH? That seems like a very reasonable pH.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    With a spillover spa, pH should be rising.
    Either there's a source of acid - trichlor pucks - or you have an autofill that leaks and low pH fill water.
    Jul 2014
    Navarre, FL
    5
    I did add pucks in an effort to raise my CYA. It was down around the 30 level, and with summer upon us I full swing in Florida, I figured I needed the CYA a little higher to keep the chlorine working at an optimum level. So is that what's keeping my Ph Low? Also, is 7.4 acceptable?
    Richard320's Avatar
    Jan 2010
    19,037
    Quote Originally Posted by Floridajetsfan View Post
    7.4 is certainly between 7.2 and 7.8, so it's fine.
    Every pound of trichlor - 2 pucks - will raise FC by 5, raise CYA by 3, and lower pH by .27 in a pool your size. It will also lower the TA some.
