Results 1 to 7 of 7
Thread: Hi need Intex pump advice
    Jun 2015
    N/A
    5
    Hello everyone one. This is my first time posting. I have a Intex pool 16x42. A week ago the pump that came with it broke. So I looked and upgraded to a Intex 2500. I ended up buying that and I am using the adapters that I bough to make it compatible with the old nozzle and strainer. I am wondering if that is ok? I am very nervous about cutting a hole in the liner. Maybe over time I will become braver. I hate to ruin the pool for my kids this summer. Also is the pump supposed to pick up the dirt that accumulates on the pool floor or just fallen debris? Please any advice would be appreciated. Since my husband has a heart attack all the pool stuff is up to me this year. Thank you 😊
    38,507
    Re: Hi need Intex pump advice
    Welcome to TFP!!!
    The pump will not pickup anything off the floor. You will need to use a vacuum attached to the suction line to do that.
    There are many many members who have added holes in their pools. Check out their pictures.
    This is a good thread:
    Useful links for fellow Intex Pool Owners
    Orlando, FL
    690
    The stuff that collects on the bottom can be reduced by adding a foot wash by the ladder. The cheapest vacuum is one that attachs to the garden hose. They are not great but it might get you through the summer. If you can spend around $100, there are many other options. Your pump is only going to pull what is suspended in the water.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Jun 2015
    N/A
    5
    Thank you for the link. I have checked out the info. I think I am gonna try and cut my pool liners. One question will I need to drain my pool? Or is there a way I can do it without that? I have already ordered the new strainer and nozzle. I am going to use a xacto knife to cut the liner. Thanks again.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,553
    No, you don't need to drain it all the way. Just drop it slightly below the lowest cut you have to make.
    Here's how far I drained to install my Hayward skimmer:
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Jun 2015
    N/A
    5
    So I just wanted to thank everyone for all the advice. I went ahead and cut the pool liner. To my husband watched in fear lol. My daughter held a bowl on the inside and my son held up the filter tube. It was a success! My pool is still in one piece and not leaking. I do have a question though. From behind the outlet there is a small amount of bubbles coming up. Most are coming through the mail valve head. Is that ok? Also my pool is off by like 2 inches in one spot. I am not sure if that is ok. We do have some wrinkles in the bottom should I drain to fix it? The pool is stable. I am sorry so many questions. Thank you for any advice
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,553
    If you have the Intex return eyeball, yes, it's normal for some bubbles to come out of the outer ring. Just so long as it's not leaking water on the outside, it's fine.
    2 inches out of level is more than recommended. One inch is the maximum advisable. But I've had one that far out or farther, and it lasted several years. If you plan to take it down at the end of the season anyway, I think you'll be fine this year. But definitely level it properly before you put it back up next year. The uneven strain on the top rails eventually caused mine to collapse once it started to rust, which all Intex pools will eventually do.
    Just keep an eye on it and make sure it doesn't continue to settle on the low side. If it does, bite the bullet and level it ASAP.
    Pentair IC40 SWG
