Thread: Cannot find pentair spider gasket multiport
    May 2014
    Dfw
    29
    The pool store says they've found a compatible entire diffusor for almost the same price as a whole new assembly. Does anyone have a source for discontinued compatible parts? I took a pic of the label on the side of the multiport valve if it helps. I searched online with no luck
    14k gallon, vinyl in ground, 1 hp pentaire pump, pentaire sand filter, taylor k2006 kit,hayward shark vac cleaner, pool blaster cg vacuum
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Cannot find pentair spider gasket multiport
    What is the part number on the top label that shows the handle positions?
    May 2014
    Dfw
    29
    272588 or 272589 hard to read
    SW Indiana
    9,199
    May 2014
    Dfw
    29
