Thread: Adding Bleach to my water - Need a good calculation
    Jul 2013
    Harrisburg, NC
    7
    I am switching to straight bleach as a sanitizer. I am looking for a good way to calculate the amount I need each time I check the FC. I know I need to increase my FC to between 7-10 PPM based on my CYA at 80. Any help here would be great. Here are my current numbers:
    11,000 Gallon Fiberglass IG pool
    Sand filter
    FC 3.0
    CC 0.0
    PH 7.6
    TA 80
    CH 200
    CYA 80
    Sep 2013
    Charleston, SC
    540
    Re: Adding Bleach to my water - Need a good calculation
    "PoolMath" button just to the right of "Forum" will do the work for you!
    5900 G Fiberglass IG pool (circa 1990), SWG Hayward Aqua Rite GoldLine (2013), IntelliFlo Variable Speed Pump (2013), Hayward Pro Sand Filter (circa 1990), Well water (no iron or other metals fortunately), test with Taylor K2006C, Charleston, SC
    38,540
    It appears you have not found PoolMath
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    Pool School - PoolMath explains how to use the link they all posted.
    Jul 2013
    Harrisburg, NC
    7
    I went to Pool Math and found my answers. Very simple. Thank you.
