Page 1 of 2 12 LastLast
Results 1 to 20 of 35
Thread: SWG-how long until it works?
    Jun 2015
    Clinton, Utah
    57
    Does the saltwater generator take several days to start keeping our chlorine levels stable? I ran it for the recommended amount of hours (3) yesterday, and another 3 hours today, but my chlorine levels are down to 2 again. Also...my CC was at .25 today. Is that bad?!
    Coleman 16'x48" AGP, Pump is what came with the pool 1,000 gallon pump I believe with Cartridge, SWG Intex brand Krystal Clear
    First Year Pool Owners
    38,295
    Re: SWG-how long until it works?
    Can you post a full set of test results?
    You should always supplement with bleach if the FC is dropping too low.
    No test measures CC in 0.25ppm increments, so not sure where that came from.
    Jun 2014
    15,149
    Until your SWG can maintain the level required, simply continue to augment your FC with liquid bleach. In the meantime, here are a couple links that discussed the SWG start-up time:
    SWG setting-first time
    Pool School - Salt Water Chlorine Generators
    If you still need additional assistance after reviewing these previous discussions, please let us know so we can get you additional help. Thanks.
    Jan 2013
    Long Island, NY
    184
    Either run the SWG longer or bump up the % of output. In the meantime, it doesn't hurt to have a few jugs of liquid around.
    Doughboy 12' x 20' Saphire semi-AG, Installed 2012
    Waterway 1.5 HP 2 speed, 100 sqft cartridge filter
    Aprox 7000 Gal, Full sun, 85K heat pump,
    TF-100 test kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,007
    If you started the pool on bleach, it should have been a fairly seamless transition. If you're starting from zero, I suspect it will take days. And if you haven't added stabilizer (CYA) it might never be able to keep up with the demand.
    Jun 2015
    Clinton, Utah
    57
    I guess maybe I did it wrong then? The TF-100 test said to check for CC to add 5 drops of R-0003 to the clear solution and if it returns pink to add back R-0871 as before and then x that number by .5 again. It turned back to pink after one drop. 1x.5= .25 right?
    Here are my full test results from today:
    FC- 2
    TA- 160 I was told to give this some time as we are just getting our pool set up
    PH- 7.5
    CC- .25
    CYA- 20 (I added more today)
    Which brings me to another question:
    Should I be testing all of these on a daily basis or just the FC levels?
    Jun 2015
    Clinton, Utah
    57
    Richard320- I have been adding bleach daily from the beginning. Just started the SWG yesterday
    38,295
    1 x 0.5 = 0.5
    You need to test the FC and maybe pH daily. The rest not as often.
    Definitely need a lot more CYA for the SWG.
    Jun 2015
    Clinton, Utah
    57
    I'm an idiot lol!! I was just going through the numbers on my calculator and not even thinking about what I was typing in! I probably hit the equals button twice when it didn't change!!
    Should I check the CYA daily until I get it right or give it time?
    38,295
    The CYA takes up to a week to dissolve and show up on the test. Just assume you are at whatever your target was when you added more.
    Richard320's Avatar
    Jan 2010
    19,007
    Quote Originally Posted by Liviesmommy View Post
    FC- 2
    PH- 7.5
    CC- .25
    CYA needs to be tested a week after you add any. Then maybe monthly. It shouldn't shift much unless you lose a huge amount to splashout or torrential rains causing overflowing.
    Pool School - Basic Pool Care Schedule has the recommended schedule.
    But feel free to test everything as often as you wish, until you get a feel for things. After a week of seeing how things progress, you'll be guessing the readings with amazing accuracy before drop one leaves the bottle. It's like having your first baby. It's okay to be nervous and overly protective.
    Jun 2015
    Clinton, Utah
    57
    lol! Okay! So, should I take out the sock of CYA I just put in since I I already added it a few days ago?
    38,295
    Depends no how much you have added.
    Richard320's Avatar
    Jan 2010
    19,007
    How long ago did you add the first CYA, and what did you target?
    CYA can take up to a week to register completely on the test. The rule of thumb is to assume that what you added is all there until proven otherwise. So... if you added enough to get to 70 and it's only been two days, yes, get the second batch out. You don't want to overshoot and have to drain.
    Jun 2015
    Clinton, Utah
    57
    I believe we added a little over a pound in the beginning and I just added 2 more pounds to the sock today
    Richard320's Avatar
    Jan 2010
    19,007
    3 lbs of CYA granules will get you to 60ish. So leave the sock in there and retest it in a week.
    Jun 2015
    Clinton, Utah
    57
    Okay thank you! This site has been so amazing!
    Jun 2015
    Clinton, Utah
    57
    I don't see on our SWG where we can change the percentage. I can increase the amount of hours it runs....
    I only have test strips to test the salt content...are these sufficient?
    Also- I'm having a hard time understanding what boost mode is? The directions say it increases the copper ions? I didn't realize that was something I had to check. I guess I need different test strips for that?
    38,295
    - You have to control the SWG output by adjusting the amount of time the pump and SWG run.
    - Forget about boost mode ... add bleach if you need to bump the FC level
    - Sometimes the salt strips work, other times they go bad.
    - Yikes, you should disconnect the wires from the copper bars .. you do not want copper in the pool. Search the forum for more info
  20. Back To Top    #20
    SunnyBama's Avatar
    Feb 2015
    Birmingham, Alabama
    21
    Do you have an Intex SWG? If it's like mine, don't worry about boost mode. If you need to increase FC or SLAM, add bleach.
    Intex Ultra Frame 20'x52" pool (10,600 gallons); Sand filter (Model SF80110); Krystal Clear SWG (Model CS8110); AquaBot PoolRover Jr. Pool Cleaner; TF-100 Test Kit with SpeedStir
