Results 1 to 9 of 9
Thread: Bleach vs. Chlorine Tablets
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    So, to maintain the chlorine level in my pool, can I rely solely on the tabs? Or do I need to be adding bleach every day? Right now I have three tabs in the skimmer closest to the pump, and two in the other. I also have some bleach on standby. You guys really helped me the other day, and my pool is back to sparkly clear!
    Wendy
    1980s 20x40 in-ground beast, 36K gallons, 4' - 8', vinyl liner, Sand Dollar sand filter, two skimmers, bottom drain, three returns
    TF-100 Test Kit
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,207
    Re: Bleach vs. Chlorine Tablets
    Tabs in the skimmer are a very bad idea as it damages the plastic parts in the skimmer and can damage the seals in the pump.
    Due to the ever increasing level of CYA/Stabilizer that tabs create we do not recommend them as a long term solution for chlorinating your pool. The use of liquid or a salt water chlorine generator are much better options.
    Support the site
    38,539
    wjaneala's Avatar
    May 2015
    Cullman, AL
    163
    So how much bleach to you all typically add to your pools each day?
    Wendy
    TF-100 Test Kit
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Quote Originally Posted by wjaneala View Post
    Enough to maintain 1ppm above my target FC level based on my CYA level per TFPC.
    In my 6700 gallon AGP its anywhere between 8 to 16 oz of 12.5% daily.
    Have you tried to use Pool Math? It's very helpful while developing your routine.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2015
    River Falls, WI
    124
    Save the pucks for going out of town and be sure to put them in a floater. Don't add chemicals directly to your skimmer, except DE additions if necessary.
    Those pucks over time will cause your CYA to creep up. The only way to get rid of CYA is draining and diluting it with fresh water. CYA is easy to add and hard to get rid of. Since your FC level is tied directly to your CYA level it's imperative your CYA level is specifically managed.
    Those pucks can also be used to incrementally bump CYA if you're looking to fine tune your CYA PPM. Use PoolMath and see how much CYA 1 puck will add to your pool. But if you get close to your upper level CYA target leave a little space for the times you leave for 4 days and stuff a floater with a bunch of the pucks. That way your FC will hold and your CYA level won't start going too high. You just want to know the exact results of everything you're adding to your pool and don't add things that you're not sure about.
    That's why a lot of the all in one type of approaches (pucks) are hard to deal with because they're doing more than just adding chlorine to your pool. Bleach on the other hand will only add chlorine and a touch of salt which is good anyway. No mysteries when all the components of your chemical balancing are ala cart.
    Don't try to move a bunch of numbers all at once either. FC is most important to just dump all at once. The other factors should be done spanning doses. It's just easier to move up to a target than to come back from an overshoot.
    ~19k Gal, IG Vinyl, Hayward SP2607X10 1hp pump, Hayward S200 Sand Filter, built in 70s, has 8 deep end with diving board, 1 skimmer, 1 return, 1 low hole, Polaris booster pump PB4-60, old Polaris robot not sure model, Rheem P-M266A-EN-C 266,000 BTU heater, solar cover, Taylor K-2006 test kit, Speedstir
    Jun 2014
    15,292
    Wendy, without test results it's also impossible to accurately answer your question, and here's why. To know how much bleach to put in (FC), you need to know your CYA (stabilizer) level. Take a quick peek at the Chlorine/CYA chart in my sig below. For example: Let's imagine your CYA is currently 50, then your target FC level would be 6, and you never want it below 4. Do you see that on the chart?
    So, how much bleach do you need to stay at an FC level of 6? It depends on the size of your pool and what your current FC level is right now. I'll use me as an example now: When my pool is balanced, I might put about 1/2 gallon of bleach in each evening. That's it. About a $1.50 worth - maybe slightly less if I really adjust my levels good.
    That's the best way I can explain it to you without getting too deep. But I will say this ..... You cannot figure-out those requirements unless you have the proper test kit (see TF-100 link below). That's a must - priority #1. Have a nice evening.
    May 2014
    Franklin, NC
    9,207
    Quote Originally Posted by Texas Splash View Post
    That is about where I am. Every time I fill my Stenner Pump tank I log how many gallons and the date. Simple division tells me that I use less than 1/2 a bottle a day (53oz to be exact).
    Support the site
    May 2015
    spring hill, FL
    40
    With my CYA at 40, my pool at 12k gallons, in Florida with 12hr sun each day, if nobody swims, I add about a quart per day to maintain 6-8ppm chlorine.
    12k in ground, 14x28 sports pool, concrete/plaster/diamond brite, uncovered
    Waterway 1.5hp pump, waterway 150sqft cartridge filter, auto chlorinator, on city water, Zodiac MX8
