Thread: Is my pool safe?
    Aug 2014
    Shickshinny/PA
    9
    Is my pool safe?
    Split by moderator from HERE. jblizzle
    Are the pools safe to swim in? We have used bromine, but nothing has ever come up in the pool store test saying that our chlorinator was working. We are now using a floating chlorinator and have bromine tables in the skimmer basket since they are not as harmful to the system as chlorine is. We added bleach to supershock the pool last evening and it instantly turned green. How long does it take to go back to normal and is it safe for swimming?
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Acid turns yellow when added
    You generally want to wait for added chemicals to disperse and circulate before using the pool. It should only take 10-30 minutes for chemicals to mix in a pool if there is decent circulation.
    Aug 2014
    Shickshinny/PA
    9
    Re: Is my pool safe?
    Thanks for the quick reply, chem geek!! I appreciate it.
