Results 1 to 16 of 16
Thread: Looking to replace 9 inch Bullnose Coping...Need Advice Please
    Mar 2015
    Norman, OK
    28
    Hi All,
    I recently bought a home with a concrete pool with 9 inch red brick bullnose coping. It has always bothered me that the coping is slightly deteriorating on many of the bricks, chipping and breaking away at the "bullnose" part. I am looking to replace them so as to improve the aesthetics as well as safety since I have already cut my finger on a sharp edge. My questions are as follows:
    Should I replace the coping with something very similar in material like a clay brick, or are there better options?
    What kind of cost can I expect? The pool is 20x40 with the corners obviously cut.
    Is it a fairly DIYable project to pop the old coping and install new? I am pretty hand, but not an expert.
    Thank you all in advance!
    26k IG Gunite, Hayward S-310T Sand Filter, 2 HP Single Speed Pump, TFTestKit, Location - Norman, OK
    Jun 2014
    15,070
    Re: Looking to replace 9 inch Bullnose Coping...Need Advice Please
    Sorry its taken so long to reply to your post. Your post has been in the queue, we're just watching for someone to reply who has experience with coping and concrete work to better serve you. Like you, I'm a DIY'er, but if you follow MY advice on this one, it may look like a jigsaw puzzle. Keep checking back with us for an update. We're happy to have you with us and hope you enjoy your evening.
    By the way, very nice looking pool.
    Mar 2015
    Norman, OK
    28
    Thank you for the reply! I figured with so many older pools out there this would be a more common question with an easy answer, but possibly not. I searched on here and google and didn't turn up too much helpful info that I could find. Thanks again all in advance!
    Mar 2015
    Norman, OK
    28
    Any advice? Thanks all
    Feb 2014
    Upstate, NY
    390
    I would think this project will be a little involved for a DIYer. You are going to have to saw cut the edges of the coping (concrete side) along the entire pool and use a chipping gun to remove the coping. It will be a mess as all or most of the construction debris will fall into the pool. I would contract this one out and get several estimates. Just a suggestion. Good luck.
    20X36 IG vinyl (18,000 gal), 3 sheer descents, Max-Flo 1.5hp VS 2300, Aquarite T15 SWG, C3030 filter, 250,000 BTU heater, Sharkvac XL (Hayward equip)
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,457
    WAY above my pay grade I am sorry to say. It is not something I would try on my own. I know how to hold and use a saw but.........
    Kim
    Mar 2015
    Norman, OK
    28
    Thank you for the replies. Could you please explain in a little more detail what you mean by saw cutting on the concrete side? I planned to use a floating insulation board or something similar to try to keep debris out of the pool, which I think would work pretty decently if held/taped firmly against the pool wall.
    Mar 2015
    Harvey, LA
    300
    I bet you'll find that the bullnose coping comes up pretty easy with a rubber mallet from the bottom of the water side of the pool...I was amazed with how easily they removed it to reset it in my recent plaster/tile job. There was one spot where they cut the mortar line with a cutting wheel, but for the most part, it came up almost completely by hand and in pieces of 4-8 bricks at a time.
    17.4k gallon IG pool with attached spa (spa itself is 730gal), Super Blue Diamondbrite plaster, Circupool SI-45+ SWG, BH/Hayward Cartridge Filter, 2hp 2speed Hayward Super II pump, , Jandy Valves, Waterway Skimmers, Rheem 400k Heater, Polaris 360 cleaner, built 2000+-, replastered June 2015, TF-100 kit---Here's my pool test reading history
    Feb 2014
    Upstate, NY
    390
    Saw cutting is when a concrete saw is used to cut concrete. A gas powered concrete saw is common for this. IMHO you will have to saw cut the line in between the coping and concrete deck. This would be the edge of the coping that is butted up to the concrete, approximately 9 1/4 inches away from the pool. If the coping was mortared/cemented in, they will NOT be easily removed. Also the reason for the saw cut will leave you a nice clean line at the edge of the concrete deck.
    Quote Originally Posted by gilbee View Post
    Perhaps you had Bullnose pavers ?? Pavers are NOT installed using mortar/cement.
    If you have an expansion joint between the coping and deck you won’t need to use a concrete saw.
    To do it right you’d have to empty the pool of water. If you want all the brick level and a nice grout line at the tile line it’s best to set the brick from within the pool. With water in the pool you’ll get dust and debris in the pool even if you put plastic down.
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by Donny View Post
    No, they were bricks just like that---over time the mortar underneath them gives from what I understand, and they start to get loose. I had a couple of loose ones, and asked the tile crew to reset them all.
    Mar 2015
    Norman, OK
    28
    Thank you all. There is an expansion joint present already, so I don't believe I would have to cut up against the decking at all and would probably be able to just keep the existing expansion joint? I have not tried pulling or knocking on any of them as I don't want to pop them until ready for the project, but none seem loose to the feel or step, so I am guessing the mortar is still fairly strong. The brick coping itself is what is aging and breaking off.
    Also, I got quotes for $1.60-$1.80 per piece for the coping. Any estimate as to how many I will need? I would go outside and count, but I am not home and the pictures are difficult to count all the way through. Pool is 40x20 with the corners obviously cut in.
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by legendss28 View Post
    Is that for labor or the bricks themselves?
    How wide are your bricks? If you want a rough number, use 120 linear feet, since it will be less with the corners cut in.
    Mar 2015
    Norman, OK
    28
    That price is just for the bricks themselves. I believe they are 4 inches wide, however the real measurement is 3 5/8 from all of the brick suppliers, so I am guessing this is fairly standard. Is this price considerably high? I am getting the feeling this kind of coping isnt as common now a days, maybe jacking the price up a bit?
    Jul 2012
    Tallahassee, FL
    30,457
    It is a retro look that is coming back so..........they are charging more.
    Kim
    Mar 2015
    Harvey, LA
    300
    Quote Originally Posted by kimkats View Post
    Kim
    I'm glad it's coming back, pool company who did my replaster wanted to convince me to replace with something else, and I immediately refused. I love the look myself...
