Results 1 to 8 of 8
Thread: DE ?
    May 2015
    Pahoa, HI
    16
    DE ?
    Good morning,
    Is this the right stuff?
    Amazon.com : Robelle 4024 D.E./Diatomaceous Earth Powder for Swimming Pools, 24-Pound : Pool Supplies Chemicals : Home Improvement
    Does anyone know where I can purchase the right stuff but in smaller quantities?
    Thank you,
    Mike
    90,000 gallon, in-ground, 3 pumps / sand filters, in-line chlorinator on #2. Learning on the job!
    38,251
    Re: DE ?
    Yes, it is DE for pools. No, I do not know where you can buy smaller bags, but I know they exist.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: DE ?
    Smallest I could find was a 20 lb. box of the stuff. Should last me til retirement as it's just a filter enhancement 2-3 times a summer when I backwash my sand filter.
    Although I hate that Clorox is branding every pool chemical and supply under the sun, here's a slightly smaller and cheaper one. Amazon.com : CLOROX Pool Garden
    Isolated Spa - 345 Gallons
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: DE ?
    You could try cellulose instead. Amazon
    Jun 2015
    Americus, GA
    1
    Re: DE ?
    I get Splash brand DE. 24lb box broken up into four 6lb bags.
    42,000 Gallon, 20x40 rectangle in-ground. Plaster walls w/ 4" tiles.
    Hayward 60ft DE Filter, AquaRite Plus Salt System, 1hp Pump
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    Re: DE ?
    Last year I bought it via the Ace Hardware website. 20# delivered to the store for $14.99, free shipping.
    Used a bit last night in the sand filter and it my water just sparkles!
    May 2015
    Pahoa, HI
    16
    Help me DE to sand filter
    Split by moderator from HERE. jblizzle
    I'm doing this today. Pump 1 and 3 have skimmer baskets at the water line. #2 doesn't; it flows from the bottom drain. Any suggestions for adding DE 11 feet down?
    Mike
    38,251
    Re: DE ?
    Why are you doing this?
    I would just add it to the 2 pumps that have the skimmers ( I assume they each have their own sand filter?) and forget about the other pump.
