Thread: Sanity check my AGP build please! 33' Sharkline, 25K gallons
    Jun 2015
    Hartford, CT
    2
    Hi Everyone -
    I'm preparing to build my first above ground pool and this forum has been very helpful, so thank you! I'm hoping that someone will lend some advice on the components I'm thinking of, for or against.
    Pool: Sharkline Heritage 33' x 52" Link
    Filter: Hayward SwimClear 225 sq ft Cartridge Filter (C2030) Link
    Pump: Hayward Power-Flo Matrix 1HP Dual Speed (SP15922S) Link
    SWCG: Hayward Aqua Rite 40K gallons Link
    So, this pool will be about 25K gallons. From what I've read in this forum, a 1HP pump should be sufficient, but the bigger the filter the better. So, for that reason, I've opted to not buy a bundled pump/filter. I couldn't find a combo unit that had a smaller pump, but a larger filter. I also read that it was advisable to up-size the SWCQ. Overall, my #1 goal (aside from BIG POOL ) is low maintenance.
    Thanks!
    38,539
    Re: Sanity check my AGP build please! 33' Sharkline, 25K gallons
    Welcome to TFP!!!
    Pump is good, SWG is good, filter is actually on the small side still.
    If your pool was open year round I would suggest a 375+ sqft filter. Although with your shorter season, you could get by with smaller. Really the bigger the cartridge filter, the less often you have to clean it.
    Make sure you add one of the Recommended Test Kits to your shopping list ... the TF-100 is the better value, plus you may want a salt test (I prefer the Taylor), and the SpeedStir is great too
    I will be installing that same pump tonight!!
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jun 2015
    Hartford, CT
    2
    Thanks @jblizzle and @Speedo!
