Thread: Quick noobie question about first time sand filter use
    May 2015
    Southern Illinois
    49
    I'm completely new to sand filters and finally upgraded to the intex 3000 gallon sand filter. My question is, I am performing the first routine backwash and there is quite a lot of sand in the sediment window. In the video is showed no sand in there, is this a problem? Should I backwash until the sand is clear?
    26' Intex 17k gallon above ground pool. 3000 GPH intex sand filter. Taylor Tech. k-2006 Test kit.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: Quick noobie question about first time sand filter use
    The sand level is probably a bit high and is getting kicked up during the backwash. If the water is otherwise clear, I'd call it good.
    May 2015
    Southern Illinois
    49
    Thanks!
    May 2015
    Southern Illinois
    49
    My PSI started out at 10psi, which is right on the border between green and yellow. I backwashed for 6 minutes and then rinsed for 4 minutes and it is still at 10psi. Is this high? In the instructional video they said when it got to that point I should backwash but it started there so not sure if there is something wrong with the filter or not.
