Results 1 to 11 of 11
Thread: Running Robots in the rain
    May 2014
    Pflugerville, TX
    148
    Obv the robot itself is water proofed. Is the transformer? We've been having sporadic showers throughout the day and I haven't tossed my robot in the pool since this weekend because I don't want the transformer to get rained on.
    Are these safe to use in a sporadic downpour?
    Perhaps I should get a small rubbermaid container or something to put the transformer in to double seal it from the elements?
    13,000 gallons w/ spa (in-ground) | Plaster pool surface
    2.5HP Jandy Stealth Pump | CL580 Filter | Polaris 480 Pro w/ Halcyon Pump | 400,000 BTU Jandy LT | Jandy Aquapure 3PPM | Jandy PS4
    38,267
    Re: Running Robots in the rain
    I used to put a bucket over the top of the transformer. The one I had appeared to be waterproof with the O-ring seal where the robot attached and the rubber cover on the switch, but I did not trust it
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Not suggesting it's a good idea, but my M5 unit has been running in some heavy downpours this season.
    Essential Links:
    May 2014
    Pflugerville, TX
    148
    I used to put a bucket over the top of the transformer. The one I had appearedto be waterproof with the O-ring seal where the robot attached and the rubber cover on the switch, but I did not trust it
    Used to? What do you do now?
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I put my transformer on a chair, tucked under a table that's near the pool. I also wrap the extension cord I use around the chair, off the ground. When I neglect to get the cord/transformer connection off the ground, my GFCI outlet has tripped on occasion when running in the rain. Certainly safe to run during the rain, provided you protect the transformer from rain and are connected to a GFCI circuit/outlet.
    Isolated Spa - 345 Gallons
    May 2014
    Pflugerville, TX
    148
    Quote Originally Posted by JVTrain View Post
    Yeah that's the idea with using some sort of rubbermaid container to put the transformer in and find a way to make sure all the cables have a toward loop so water runs off the cables rather than toward the transformer/container.
    Aug 2014
    East Northport, NY
    155
    I put a bucket over the transformer
    IG Vinyl -30,000 (20x40)
    Hayward Pro Grid DE Filter/Hayward rebuilt 1 HP Pump
    AutoPilot DIG-220 RC52 SWCG
    TF-100 Test Kit
    Aquabot Bravo
    38,267
    Quote Originally Posted by Mindflux View Post
    Use a suction cleaner because the 2 robots I had stopped working.
    May 2014
    Pflugerville, TX
    148
    Last night I ended up putting the transformer on top of my pool heater (curved top) and inverting an igloo cooler over it. My Aqualink PS4 is right next to the heater with a GFCI outlet on the side of the box. Worked out OK, transformer stayed dry.. pool robot ran OK.
    Feb 2014
    Central Minnesota
    5,080
    I'm sure that would work fine. Just make sure the heater isn't on!
    May 2014
    Pflugerville, TX
    148
    Heater is never on except if I'm in the Spa which is.. almost never.
