Results 1 to 13 of 13
Thread: Newbie to This Forum - Not to The Industy
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    I'm from the "dark side". By that I mean I'm from the traditional pool care/construction/pool store professional side of the industry. I worked as a pool salesman, pool store retail manager for a two-location dealer, and a manufacturers' rep for 15 years before coming to the distribution side of the industry, where I currently work.
    I try to stay open-minded, using the belief that "whatever works best" for your pool, spa, grill, etc., is the right solution. I also strongly believe that even two side-by-side residential pools in two backyards, even with the same equipment, may NOT have the same problems or solutions thereto. My special areas of "expertise" include automation, heaters, heat pumps, pool paints, equipment, and stone.
    For the record, I rep'd for Pentair, Jandy, Polaris, Intermatic, Raypak, Quaker Plastics, Fiberstars, Florida Falls, Spillway Spas (Baker Mfg), Ramuc, Olympic Coatings, and a whole host of other, smaller comanies before coming to distribution. My water analysis and troubleshooting skills are probably considered "advanced", but not at the molecular chemistry level. The water chemistry experts on this forum appear to be way ahead of the curve, and I'd yield to them always.
    My "favorites" file contains links to about 175 manufacturer's websites and I can reference a good bit of tech information from those, or refer you there as needed. Granted, you will get "their" side of any story, but unless you built your own SCG or filter, it may be of help.
    I will be here learning more.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    SeanB's Avatar
    Mar 2007
    Missouri City (suburb of Houston, TX)
    2,622
    Re: Newbie to This Forum - Not to The Industy
    Welcome to TFP!. I have set your rank as "In the Industry" which just helps folks know who they are talking with. We look forward to learning from your expertise!
    I think you'll find the methods we typically recommend here are not as alternative as you might think. Mostly we just recommend regular testing with a quality kit, and advocate the use of household chemicals with the same active ingredients as those found in the pool stores. However, I don't personally have any issue with people buying their chemicals at the pool store - I often do myself. My only hope is that they read up and know what they are shopping for and why. I'd like to think that TFP members are some of the most educated pool store customers out there!
    Sean
    TFP Founder
    My Pool: 13K gal IG gunite with 7' spa, Pentair Cartridge Filter, Intellichlor IC40 SWG, Polaris 280 Cleaner, TF-100 Test Kit w/ salt test.
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum!
    You're done SLAMing when:
    H2O_Keeper's Avatar
    Nov 2008
    SW Indiana
    140
    I can be unbiased as not being in the industry nor being affiliated with TFP. If you want a unbiased opinion and help with pool care then you are on the BEST site on the internet!!!!!!!!!
    For me most all of my questions (75%) I come up with can be found in Pool School (Dont miss "further readings"!). The next 20% can be found using the search features. There have even been a few times I didnt think the info was there and did a post and later found a similar thread existed. Its an awesome database of information. You have it, chances are its already been adressed somewhere here!
    I have to agree with SeanB, they are not trying to push Clorox on you as a sanitizer, only educate you on the options and science if your interested to that level of pool care.
    Your experience will be great for very specific questions to equipment, etc...Who knows you may have an unusual situation come up and want to see if anyone else has the missing data on this forum.
    Welcome.
    21K Gal, IG, Vinyl, Bleach-Borax-Baking Soda, 3/4HP Hayward pump, Hayward sand filter, 200,000BTU Heater, TF100 Testkit
    "All that we are arises with our thoughts." - Buddha
    “When fate hands you a lemon, make lemonade.” - Dale Carnegie
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Thanks for joining up, Budster!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Welcome!
    Quote Originally Posted by H2O_Keeper
    ... they are not trying to push Clorox on you as a sanitizer, ...
    I now have a mental image of SeanB and the mods standing on the street corner with quarts of clorox under their trench coats!!
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    Guest
    Welcome to TFP. You are bound to be a valuable addition to the fourm!
    budster's Avatar
    Dec 2008
    272
    Thanks to all! I never stop learning, and yes, I've been known to recommend bleach as well, I just don't stock it because of shelf-life issues at my type of business.
    Guest
    Quote Originally Posted by budster
    Yep, that seems to be the domain of chemical houses like Brenntag and Hasa, although Arch (HTH) does package 10% sodium hypo in gallon jugs for retail sale.
    budster's Avatar
    Dec 2008
    272
    Quote Originally Posted by waterbear
    Yes, we can get it from them or even a local source. We do stock and deliver Muriatic Acid so transportation and storage issues are not prohibitive. I have a number of retailers who have 700-900gal. tanks, and despense liquid chlorine to their end users in "jerry jugs". I sell the jugs with glee! There seems to be some recent issue with those liquid chlorine suppliers, though. I'm not sure what it is, but the closest local source for my dealers is in Jacksonville, and and one of my dealers complained they could no longer get it. If that keeps up, perhaps I should revisit the bleach market!
    Guest
    We get ours from Jacksonville also, since we are located in St. Augustine, and have not had any problems so far. Then again, I am on vacation from that job until March so if anything happened in the last 2 weeks I would not know about it! (It's actually my summer job )
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    That is what I used most of the summer...found it at my local ACE Hardware for $3.48 a gallon...which when it comes out in the mix 10% vs 6% bleach...I ended up at about the same or a little ahead...For maintanance I would use about 3.5 cups per every other day usually. Sometimes after heavy uses...usually on Sundays...I would add almost four cups. Then a couple of times per month I would add a pound of shock...This worked best for me...That is all I ever bought last summer...other than buying some CYA late in the summer when we had lots of rain and had to drain down the pool three or four times...and CYA fell. I spent less than 100 bucks on chemicals...
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
