Results 1 to 15 of 15
Thread: Used Raypak Heater
    Jul 2010
    OH
    5
    Used Raypak Heater
    We need to replace our Hayward H250 pool heater and need some advice. Our neighbor is filling in his pool and has offered us his 10-year old 266K Raypak digital unit free of charge. It hasn't been used in 3 years and I will have to pay someone $500 to move it next door to our house to see if it'll work. It is very tempting as I am getting quotes of $3200 - $3500 for purchase and installation of a new unit. I also don't understand why the pool company quotes are so high. The pool stores sell the same heater for much less. Any advice is appreciated.
    1) 28,000 Gallons (20 x 40)
    2) Hayward Pro Series Sand Filter
    3) inground, vinyl liner
    4) Hayward 1.5 HP pump
    May 2015
    Buffalo NY
    15
    Re: Used Raypak Heater
    Why dont you move it and install it yourself? It is not that hard at all. Im almost positive you will need a longer piece of black pipe as the hayward heater gas valve is on the left side and the raypack is more in the middle of the unit. You will also need the manifold ends for the raypack heater as they are different than the hayward. See if you can get them too and you would only need to use a union to connect the water pipes. Its not that difficult of a job at all and probably would only take you two hours yourself.
    40,000 Gallon Swimco vinyl liner inground pool, Hayward Perflex EC75, 3/4 hp pump, Jandy LRZ325EN gas heater
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    $500.00??? Find someone else to install it...
    Factory Warranty Station for:
    Jul 2010
    OH
    5
    I was told we needed to have a certified gas plumber install and hook it up. What do you think the chances are that it'll work. Also, can anyone tell me why the pool company's charge so much for a new heater and installation?? Why is that I can order a brand new unit off of Inyopools for @ $1500 yet they list $3000 on their quote? Am I missing something?
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Did the certified gas plumber tell you that you needed a certified gas plumber? Just kidding, depending on local regulations that might be required but even then that might just be the gas. You could still get a dolly, move it to your pad, plump it (or hire that done by a handyman). Then hire plumber just for gas connection.
    The price difference is why the brick and mortar stores, especially speciality stores (like pools) can't complete. Not that I feel bad for them necessarily, but they just don't have the volume to match pricing of an internet provider that never handles the product but rather just processes an order and a drop shipment from the manufacturer or warehouse.
    BTW, my experience with inyo was good. There are some disclaimers on warranties on internet purchases that you should consider as well. Though it wasnt worth $1500 for me.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    wjr75's Avatar
    Jun 2013
    IL
    836
    Not sure where you are located but the one I just replaced a few years ago in the Midwest was around 10 years old. I dumped about 500 bucks in it the prior few years. I wish I just had bought a new one instead of repairs prior. My 400btu was qouted from a pool company at $3300 bucks installed. I ended buying it from the internet for $2000 and installed it myself. It was a direct replacement so all the PVC lined up but I just had to add some water proof conduit for the electronics since they moved the insert up on the newer version.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jul 2010
    OH
    5
    Quote Originally Posted by wjr75 View Post
    I am in Ohio so I suspect wear and tear would be similar. I am tempted to just order it off of Inyo and hire someone to install it or do it myself. Thanks for feedback.
    wjr75's Avatar
    Jun 2013
    IL
    836
    You may want to consider the 400k size if you can swing it. It will heat on demand a lot faster.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    $3200-$3500, I would hope that is for a 400K BTU unit.
    As for the $500 to hook one up, if they are doing everything, electric, plumbing, and gas, I'd say that's about right. If I did that type of thing I wouldn't charge less than $400-$500.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Jul 2010
    OH
    5
    Quote Originally Posted by ps0303 View Post
    Nope, charging that much for a 266K unit. I can't remember exact reason for their much higher price - I think one guy said you don't get a good (or any) warranty when you order it offline. I believe I read on Inyo's site that the one year warranty is good as long as certified installer install the unit. I am not sure what constitutes a certified installer or where i find one in Cbus. Need to make a decision soon - the pool is way too cool for me.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    If you are not having to pull a permit to do this install (no inspection upon completion), i would say, who will know if i used a cert plumber or not?
    If you buy the heater from a local guy, you should be getting the full warranty from the manufacturer, unlike if you buy online (30-60 days). This (no warranty) is what the manufacturer should be beginning to do to help out the B&M shops. When you buy online, B&M are trying to make up for the lost sale buy charging a flat fee to install that item (500.00), weather the install is easy or not. You also have to understand that costs to come out, pay a tech, pay insurance(s), pay fuel, pay W&T on the vehicle, etc, add up. We are beginning to do the same, for better or worse. We usually give a little on the install when you buy item from us, markup makes up the difference.
    Online prices are great when you are on that side of the fence, but it's killing us...
    Edit after reading your post: Manufacturers should still be phasing out any kind of warranty longer than 60 days regardless of who installs for online purchases.
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Quote Originally Posted by Pool Clown View Post
    Amen!
    Paul
    Apr 2010
    Central NJ
    227
    My Raypak 406A cost 2,800 with installation, I don't see how a 266k could be more. If you are going to upgrade to a larger heater, make sure to verify that your gas line will support it.
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Apr 2010
    Central NJ
    227
    I'm all for supporting local shops, as I believe they have their value. I do put my money where my mouth is, as I have paid more to local shops when I could've bought it cheaper over the Internet or at a big chain store. But when somebody is quoting 3,200 - 3,500 for 266k heater, they can't complain when the customer goes somewhere else (local or not).
    ps0303's Avatar
    Jul 2011
    FL
    3,711
    Quote Originally Posted by jrguzmanr View Post
    That price is crazy absurd for a 266K unit. That lower price is more inline for a 400K unit.
    Paul
