Thread: Pump and Cleaner wiring diagram
    I leave my pool in the hands of relatively inexperienced maintenance people from time to time and need to have it fairly well automated and electronically controlled. I use two timers, one on the main pump and one on the cleaner robot. And I have a thermostat to protect against frozen pipes. ( I live in southern Mississippi where we don't drain pools but temps can drop to the low 20's). I've developed a fairly simple control system using relatively inexpensive parts.
    The heart of the system is a pair of Tightwatt timers to control the main pool pump and the cleaner. The Tightwatts are electronic timers that allow simple programming to vary the time the pumps run according to the season of the year. I have them set to run the pool pump for 16 hours in the summer in two 8-hour segments starting at 2 AM and 2 PM and 8 hours in the winter, also in two 4-hour segments. The Tightwatt knows the current date and varies the run time as summer turns to winter and back again. The timer for the cleaner is set to run for one hour a day year round. (Of course I can vary the cleaner time as circumstances warrant).
    I use a greenhouse thermostat to protect against frozen pipes. There are several pool thermostats on the pool product websites but they seem expensive. The greenhouse thermostat from KKontrols does the same job at much less cost.
    I've attached a schematic wiring diagram to show the electrical hookup I've developed.
    20,000 gal. Vinyl
    1.5 hp pump 300 lb. sand filter.
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    Re: Pump and Cleaner wiring diagram
    Sounds a lot like what I'm planning to do, but better. I was just going to use 2 analog timers for my two pumps(spa and pool). The Greenhouse timer is a brilliant idea, I might copy that! Then I won't worry about my spa pipes freezing at night.
    P.S. The schematic isn't showing up for me, nor does it say anything is attached.
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    I'm having difficulty uploading the schematic to the forum. I'd be happy to provide you a copy by email. Respond to: if you'd like to try that.
    20,000 gal. Vinyl
