Thread: Hayward sand filter reassembly
    I have a Hayward S310S sand filter and took it all apart because I was suspecting a damaged lateral. During disassembly, I noticed that the upper elbow and diffuser just pulled apart easily, but the lateral assembly was bonded or puttied to the lower elbow and the flange ( aka bulkhead fitting according to the manual).
    I ended up having to put the lower elbow in the vise and use a 2x4 to twist the lateral assembly off of it. It seems like it wouldn't need to have glue since it has 500# of sand sitting on it and even backwashing probably wouldn't make it move.
    When I reassemble it, should I use putty or glue or just press the pieces together?
    Thanks in advance
    SE Kansas
    25,000 gal in-ground fiberglas
    Hayward S310S Filter
    Hayward Super II pump
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Hayward sand filter reassembly
    I would think press fit myself.
    Support the site
    Quote Originally Posted by tim5055 View Post
    That's what I thought. If the upper elbow (which is above the sand) would stay together during all the different phases of water flow (filter, backwash, etc.) It seems that the lower assembly wouldn't come apart either.
    SE Kansas
