Results 1 to 7 of 7
Thread: Cheapest Bleach in Houston?
    Jun 2015
    Houston, tx
    21
    I've seen a few people from Houston posting and was wondering where everyone has found the cheapest bleach.
    So far, the best I have found is Aldi's 8.25% which is $1.29 for 64 oz.
    I would love to find something cheaper, hopefully more concentrated and in larger jugs.
    Any suggestions?
    In ground 30,000 gallon rectangular plaster/pebble pool, hot tub with blower, 2 HP Pentair WisperFlo Pump, 420 Pentair Clean and Clear Plus Cartridge Filter, Pentair Rainbow 320 Chlorinator, Easy Touch Control System, Pentair 400K BTU heater, Interfab G Force Slide with dedicated 1 HP pump, Travertine Decking, CoverStar automatic pool cover
    Nov 2011
    Magnolia Texas
    80
    Re: Cheapest Bleach in Houston?
    Walmart 1 gallon of 10% for $2.98.
    28,000 gallon salt water pool
    DE Filter
    Inground plaster construction
    1-1/4 hp pump with 1hp booster pump
    Jun 2015
    Houston, tx
    21
    Quote Originally Posted by Boland01 View Post
    I was at Walmart yesterday and I only saw their 8.25% for $2.98. Maybe my store just gets the cheap stuff
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Texas is one of those state that bulk 10/12.5% is usually readily available. I would call around to local pool stores and see if they have it. Usually I would direct you to the HASA dealer list, but apparently they have not expanded to Houston yet.
    Support the site
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    It is in Houston, not sure about any other metro areas, but it is not anywhere near me outside of buying in bulk 55 gallon drums. You can get 10% from janitor suppliers, but it's outrageous in price.
    Essential Links:
    Jun 2014
    15,004
    Typically I go to Wal-Mart or HEB for the standard generic bleach at just under $3. Just convenient for me.
    Jan 2015
    Anthem, AZ
    188
    The price should be based on chlorine per ounce, not total price.
    Chlorine Price Per Ounce Calculator
    adli's is the cheapest per oz i've found, with lowes 10% being next cheapest. costco is in 3rd place.
    19K IG Pebbletec with attached spa. 60sqft Cartridge filter, Intelliflow VS, 399k BTU Gas Heater, Pentair IC40. Phoenix, AZ, full sun.
