Thread: How to fix water without a pump?
    Jun 2015
    White Bear Lake, MN
    6
    We just got a pool last week that came with a pump but the pump stopped working 2 nights ago. I'm wondering what to do in the meantime to keep the water good. We had been using chlorine tablets on the pump and all the numbers were great aside from ph so we added baking soda to fix that. I'm worried everything will get messed up if I wait too long to do anything to the water while trying to get the pump fixed. How long does it take for algae to grow and water to get bad?
    Summer Escapes 12 ft AG Ring QuickSet Pool, 30 inches deep, 2100 gallons, RX600 Polygroup Cartridge Filter System. Water Testing: hth multi-purpose 6-way test strips
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: How to fix water without a pump?
    Welcome to TFP!
    This thread has lots of good information on what can be done in this situation: Newbie trying to avoid a problem!!!!
    Jun 2013
    Freehold NJ
    133
    Only thing I would say is get some floaters at Walmart and put them in. Take the motor to a motor shop and either have it replaced or repaired.
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Pour couple cups of bleach in each day and brush to stir it up hopefully to keep algae at bay. Without knowing your CYA pucks could be tricky. Also get a good test kit. With 2100 g. You can always dump and start over.
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
